Results 1 to 8 of 8
Thread: another manual conversion thread
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Red face another manual conversion thread
    hey everyone..
    considering doing a manual conversion on my VK soon..
    i can get a rebuilt aussie 4-speed, bellhousing, new clutch and thrust bearing and a flywheel together..
    i know that ill need a clutch cable, pedal box and spigot bush, but unsure on whether i can use my VK's tailshaft with the aussie 4speed?
    yeah ive done a search but the only info i've found on using the auto tail shaft with a manual box is for the 5-speeds... still not sure if the auto one will bolt up to the 4-speed.
    also is there any other parts i will need that i left out thanks
    thanks in advance
    NOT.BT1's Avatar
    NOT.BT1 is offline Bogan pride
    VN exec project vh in the shed
    Nov 2006
    geelong victoria
    you'll need a manual console um im pretty sure when my cousin put a manual 4 spd in his vc he needed to change the tailshaft as well not completely sure i'll give him a call tomorrow and find out unless someone else can answer before
    Quote Originally Posted by neet_wagon View Post
    Instant Failure!
    What exactly IS a VD commodore? Is this some super hektic cop-special I've been missing out on?
    Quote Originally Posted by ari666 View Post
    basically OP is saying he has VD in his crapbox???
    didnt know you could get herpes of the anus, but hey! who am i to judge. have fun with your herpes OP!
    Feb 2006
    Radelaide
    the 4-speed i can get is an M20. as far as im aware the VK's came with the MC6? is there any difference in strength between the two? would the M20 be fine behind my 202 with holley, exhaust etc (maybe later EFI)
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Sure the M20 would be fine behind the 202. Its is a lot stronger than the MC6 tranny.
    As for the tailshaft, i think it won't fit, i'm sure the MC6 has a longer rear extension housing, which would make the tailshaft shorter.
    Feb 2006
    Radelaide
    my car is auto at the moment.. so it wouldnt have a manual tailshaft. or are they the same from trimatic to MC6? thanks for the help
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    The trimatic and M20 tailshafts are the same. AFAIK The MC6, M75 and M76 tailshaft are different to the M20/M21 and trimatic ones.
    Feb 2006
    Radelaide
    ok thanks for that. that will make the conversion easier
    apart from:
    gearbox
    bellhousing
    clutch
    thrust bearing
    flywheel
    clutch cable
    pedal box
    spigot bush
    is there anything else ill need?
    thanks for the help everyone
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    needs a good cam i know where you can buy one lol
  1. Replies: 20
    Last Post: 19-12-2007, 03:39 PM
  2. WTB: Manual conversion or wrecked vn-vr manual
    By na3point8 in forum Parts And Other Items For Sale
    Last Post: 13-03-2007, 10:22 PM
  3. manual 6 conversion to 8...
    By betts in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2007, 05:01 PM
  4. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
  5. Manual conversion
    By Robbo74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2004, 11:13 PM
