hey guys im just wondering what other parts i need to fit tripple su carbys to my black 202 i know i need the manifold and carbys ofcourse but im just wondering what eles needs to be changed or replaced to fit it all.
cheers, nic
bumpage i cant be the only one who is doing this mod?
i have thought about it but havent got the cash flow your is adelaide so give parts SA a call (08)82517066 they are the south oz supplier of redline performance manifolds or check out www.redlineauto.com.au might find some info
You will need a linkage kit to make all the carbies operate off the one accelerator cable and a block for the fuel lines so your fuel supply hose goes into it and has three hoses coming out. Biggest hassle will be with the PCV valve and hoses. When i had triple SU carbies on my HQ i ran an oil filler cap off an early red motor which has a breather in it and i used a snorkel off a HR holden to go in where the PCV valve was. The snorkel is just a bit of pipe with a 180 degree bend at the top which fits into your rocker cover and runs down the side of your engine to sump level as a breather. An early red motor rocker cover will fit your black motor and it doesn't have the hole that goes to the air cleaner like on your motor
i have the triple carbs and i may be getting a black 202 so il have a play around and see wat I can do
how much did you buy the carbys for?? coz very interested in that
