Results 1 to 10 of 10
Thread: upgrading alternator in vk 202
    VK
    Jul 2004
    Default upgrading alternator in vk 202
    Hi everyone,
    i just recently got some new subs in my vk and they chew through a lot more power than the old one, and my alternator cant cope. When the stereo is up loud it'll sit on around 9-10v. I'm wondering if a later model commodore alternator will fit on? Also, i heard the vk calais have a better alternator than the lower models- can anyone confirm this? If so ill just swap em over
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Maybe its your battery? is it old? have a good earth? i can run my amp and sub for half an hour with the car off and still have just over 12v.
    u must have some setup..
    do u have an amp?
    Ive had my system run for about 2hrs or more and still be good.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VK
    Jul 2004
    na my alternators stuffed, and i'll be changing it regardless. Just wondering if i can change it with something better.
    Another question, is there any way i can get my headlights to go brighter (upgrading wiring or something)... my car is suffering from the old vk dim lights syndrome. Im assuming upgrading the earths will help improve this?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Yeah, A VR V6 85amp Bosch alternator will bolt up just fine you will need to remove the pully from your old alternator and fit it to the new one. You will need a rattle gun to do this.
    If you choose to use a VN-VS EFI V8 alternator it will have the correct pully but you will need to reverse the bracket housing to do this you will need an impact screw driver.
    To wire it up its slightly different to a VK, you will need a fuel injector plug available from wreakers second hand or new from repco in packets of 2. The plug will fit the plug on the alternator. You will need to wire it up tot he battery and trigger as usual but it will also need a warning lamp wire for your dash else it wont charge.
    cheers
    Scott
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    VK
    Jul 2004
    goin by what the other guys say id say doubtful for a straight swap.
    does anyone know the amp rating for the vk alternator (carby and efi) and whether they are different?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Vk alternator efi is 55amp i think. for upgrading your alternator u can get an 85amp from a vn or even a 100amp from a vt and modify, the oldholden pedia has a great guide.
    link: http://gallery.oldholden.com/ReaperH...adeAlternator/
    Cheers Tom
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by phat_com View Post
    would a vn V6 alternator bolt straight on an efi 6? (still vk's here)
    A V6 alternator will nearly bolt straight up you will need to change the pully, refer to my post above.
    cheers
    scott
    blakestone01's Avatar
    blakestone01 is offline No dice..
    Vk
    Jul 2006
    Narre Warren Sth
    Quote Originally Posted by bezz_86 View Post
    Mate I have the same problem. I'm thinking it has something to do with the old wiring aswell. Anyone here fixed this problem?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    When I fixed the problems on my VK ages ago, I installed a 85amp alternator off a V6 using the VK pully, put a new charge wire to the battery, and new earth straps from the block to the body & to the battery. After that all my electrical problems were solved.
    If you use a later model alternator you can either use a V6 85 amp or a 120amp from a series 1 VT 5L NOT the 5.7L series 2. see my first post for info.
    cheers
    Scott
  1. upgrading 202 to Vn V6
    By V-ahhh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2006, 06:22 PM
  2. Upgrading VN ECU
    By jamieaus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2006, 07:38 PM
  3. Upgrading a VS 3.8 to VS 5.L
    By NeilB in forum V8 Development and Modification
    Last Post: 31-01-2006, 12:16 AM
  4. vt upgrading
    By phoenix_984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2005, 08:30 PM
