Results 1 to 5 of 5
Thread: Power steering questions
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Default Power steering questions
    The first question. When changing from power steering to manual steering and vice versa does the lower steering column piece that connects to the rack need to be changed over as well?
    Is it possible to relocate the power steering reservoir thing? Like at the moment it's mounted near the batter, and I want it moved down the back somewhere, like maybe on the firewall. Would that be possible if I moved the plumbing as well? Can the reservoir be mounted lower then the pump? On our VH wagon, the reservoir is like built in with the pump...not 100% sure coz I haven't taken any notice,..but it sits with the pump or sumfun, is this setup better to use?
    I'm thinkin bout converting to manual steering coz I want my engine bay as neat as possible, but if I can do sumfin to minimise the mess the power steering gear leaves I might just keep power steering.
    Sry for asking ****loads of questions lately, but hey I gotta learn
    Cheers.
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    yes you need to replace the lower part and i think maybe the whole shaft
    yes you can move the resevoir but it needs to be higher then the pump so you can bleed it
    go manual, they dont need power steering unless your a nancy
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Spank my ass and call me Nancy. Keep the power steering, you can neaten it up by putting braided hose covers on.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    You need to change the immediate shaft, yes this can be done with out taking out column but have fun specially if your engine is in. just remove the whole collumn and replace the immediate shaft. put your reservoir where ever you wish just make sure ur lines dont get in the way of to much heat, im relocating mine to the drivers side. also you cant us the setup like Vh caus u have an alternator their though if your running EFI it may be possible by putting the alternator where the vacumme pump goes and then their should be room but would be hard to put oil in etc.
    Cheers Tom
    DANNY8's Avatar
    Apr 2004
    Thx mate. On my motor which is going in (mild 173) the alternator is on the passenger side down bottom, and the VH power steering pump goes on the driver side top. Where the air pump use to be I'm saving that spot for a SC14 to mount. So hopefully it should all fit.
  1. VH Power Steering..Trade For Manual Steering
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2008, 12:23 PM
  2. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  3. VH Power Steering..Trade For Manual Steering
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 28-01-2007, 02:29 PM
  4. vr questions re gear box and steering
    By artrix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 06:47 PM
  5. Questions regarding VR wagon smokey engine and power steering "hiss".
    By jayseventwo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2005, 01:32 PM
