Results 1 to 2 of 2
Thread: vh 253 missing when starting at trafic lightsat
    vh slx 253
    Mar 2007
    Question vh 253 missing when starting at trafic lightsat
    engine miss firers when starting off car runs on lpg
    THING I HAVE DONE changed all spark plugs this made car run ok for a short time. it was notice when spark plugs were changed number 6 cylinder plug was black, exchanged plugs in number 5 and 6 this made a run ok for a short time. replaced igition lead to number 6 cylinder no change in fault. removed plugs from cylinder 5 and 6 compression checked each cylinder reading 150psi. there is no blue smoke or oil useage what is wrong ????? help i am drowning
    BeNoS's Avatar
    BeNoS is offline PROUDLY ON THE PUSHY
    1000hp trek pushie (on a good day)
    Jan 2007
    Gold Coast
    possibly check the dizzy cap and rotor make sure it isnt burnt out at all also if u have multimeter check the leads they would be the other things i would check first and also check ur timing make sure its within specs for the car running on gas timing is different to petrol running engines if i remember correctly
    hope this helps
  1. Missing
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2007, 05:29 PM
  2. VS missing
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2006, 04:18 PM
  3. missing
    By ab56452001 in forum Electrical Wiring / Questions
    Last Post: 25-11-2006, 06:46 AM
  4. VT missing
    By horndog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-06-2006, 09:49 PM
  5. HELP! VN starting and missing issues...
    By fallen in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2005, 01:10 PM
