Results 1 to 15 of 15
Thread: removing vk front seats
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    Default removing vk front seats
    ey
    i wanna get new front seats for the vk and im goin to u-pull-it 2mw to get sum, ive look on my car and cant seem to find a way to get them off, has ne 1 dun it b4, or if ne 1 knows how to do it???
    thanks
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    easy, I did mine the other week. I say easy, cus the VL ones are painful!!!!!
    13mm Socket & rachet is your friend, they are held in with locktite also, so you might need some muscles.
    I found that a screwdriver also comes in handy as seat rails tend to have some **** in them from sitting around, & the seat will need to go all the way forwards for rear 2 bolts, & all the way back for front 2 bolts.
    I had to unjam both seat rails on both seats to get them to go all the way in either direction (damn me being a shortass!)
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Sometimes they use a hex head bolt.
    Instead of putting second hand VK seats in, why not put VN ones in? We got given a pair of VN seats about 3 weeks ago and Brad put them in the other day. Just had to switch the rails over, and also the driver side I had to do a bit of welding and customising....other then that it was ok. And they're heaps better. I didn't think they would be much different to start with but everytime I get in it feels wicked!
    NORTI's Avatar
    May 2004
    Quote Originally Posted by VHPirie View Post
    I found that was the case with the VL's but not VK's?. in both the VK Calais I pulled the seats out of last week, didnt have them, makes things alot easier.... the other heads have a tendancy to round off due to the force needed to crack the locktite.
    Instead of regular VK Seats.... go the Calais ones..... they still beat VN seats
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    Default seats
    went to u-pull-it 2day got the seats but only the back 1's cause i didnt have enough $$ for the 2 fronts as they cost $44 each so i'll mite get them wednesday heres a pic of the bk 1's i got , i also got the door trims aswell, im slowly changin the interior colour as it is green n changin it to blue.
    Attached Thumbnails Attached Thumbnails removing vk front seats-leather-interior.jpg
    vc sle vc sl wagon
    Apr 2007
    st marys
    3/8 drive ratchet or 1/4 braker bar 13mm 6 sided socket to crack them lose then a 13mm rachet spanner should do it dont crack them with a rachet spanner there good but they will brake
    in my old vk the seats where stuffed so i went to upullit and got vh sl seats dark blue fronts with the green backs and dark blue sun visors cause the car had the green interior it looked gr8 then green vk calais door trims
    NORTI's Avatar
    May 2004
    dijim8 - did you happen to know if there was many cerulean SL interiors there? I dont suppose you need/grabbed the front door arm rests?
    dijm8's Avatar
    VZ SS LS3
    Jun 2006
    i dnt knw bout that i didnt reli look around wen i went ther last week i saw the car with the seats i wanted then went ther the other day n just got them n walked out but i shud b goin ther wednesday so i can chek for ya
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by dijm8 View Post
    A member on here ENVS or ENVSV6, has a front pair of VN seats for $50 I rekon....he's in Murray Bridge.
    NORTI's Avatar
    May 2004
    yeah thx, was going to go today, but I wont be able to now.
    also Id remove ya sig links before you get into trouble
    VN Executive Series 2
    Oct 2005
    hi guys,
    im also struggling to remove my front seats on my VK. I have an 85 Vacationer sedan and i'm stuck at point 1 - removing the allan head bolts (?) that secures the seat into the floor, as per the attached photo.
    How would i go about getting it off - it seems in previous posts that you could use a "3/8 drive ratchet or 1/4 braker bar 13mm 6 sided socket to crack them lose then a 13mm rachet spanner should do it dont crack them with a rachet spanner there good but they will brake."
    As the front ones are stuck in with locktite, ive tried just manually moving them with allan keys and they are just in too tight. I cant get my socket wrench to fit in there with the allan key head attachment as the seat gets in the way...
    Also, is there any product that can melt locktite?
    If someone has done this before, could you please find a pic of the tools I would need?
    Oh and before I even go this far, do you guys think I should proceed with it anyway - im taking my current seats out to put in VK Berlina seats, however the berlina seats dont have any rails, so the rails need to be transferred from both of my seats to the berlina seats too?
    cheers
    Kurt
    Attached Thumbnails Attached Thumbnails removing vk front seats-passenger-rail.jpg
    NORTI's Avatar
    May 2004
    hmmm must be late VK's & VL's that have allen key heads (Hex) In my VL's I used a allen key, & a piece of pipe as a breaker bar. I ended up having to angle grind one bolt off - Avoid this at all costs. Because basically your seat strength is then ruined.
    I had heard once before of stuff that could help dissolve locktite, but Ive never seen it ya just have to have the muscles
    kellyvk's Avatar
    kellyvk is offline kellyvk
    vk calais 5L/ vk commodore 6
    Apr 2007
    sydney
    I figured it out as i put some clean seats in from another vk. Just four bolts all up, front and rear, they sit in the rails.
    NORTI's Avatar
    May 2004
  15. #15
    VK
    Jul 2004
    guys spray Selley's RP7 on the underside of the bolts to grease them up, then use an allen key and a metal pipe for leverage to get the bolts off. The Loctite shouldn't be a problem now. That and rp7 smells nice . Good Luck everyone!
  1. removing front seats
    By Co0kiE MoB$tA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-03-2010, 05:30 PM
  2. Problem removing front seats
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2009, 02:42 PM
  3. removing vk front seats
    By Vk-5ltr Berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-01-2007, 06:52 PM
  4. removing front seats
    By run in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 02:04 AM
  5. Removing front seats with SRS airbags
    By 1 SLY VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-01-2006, 11:15 AM
