Results 1 to 16 of 16
Thread: Trimatic.. how much power can they take?
    Vk calias
    Aug 2006
    Default Trimatic.. how much power can they take?
    How much can they take without modification. Im getting a 400 od hp motor and i want to know how long the auto will last. Also im wanting to put around a 1500 stall convertor, I hear that they do this by modifieing the existing convertor so how is it done and how much will it cost?
    The other option is to put a supra 5spd behind it what would this involve apart from the obvios pedalbox, tailshaft, crossmember?
    Vk calias
    Aug 2006
    ok so asked a few ppl a few questions today and found out that
    1) 1500 stall is way to small I need more like a 2500-3000
    2) Stock trimatic can only take a liltle bit more than the stock power of a 308
    3) I need atleast a stage 2 shift kited box whitch also involves adding stronger clutches and a few other bits and peices.
    So if anyone has a shift kitted (stage 2 at least) trimatic they want to get rid of let me know please.
    Another think i need to know is the specs of the cam so I can figure out wheather the stall will be right, all i kinow is that its "auscar" spec if anyone could give me futher info on what spec cams auscars might run and more inportantly when the fun will start please let me know
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    If its for the VK why not go for a a 4 speed auto from a 5L VN?? You should have more options to make it stronger. Bolt pattern should be the same. Its not computer controlled so it should work alright.
    cheers
    Scott
    VK Commodore
    Sep 2006
    Quote Originally Posted by vkberlina View Post
    cheers
    Scott
    You'll need to change the block if you want to run a turbo series gearbox.
    There is 2 patterns
    Holden Patten suits trimatic
    Turbo pattern suits TH350,TH400,TH700
    I run a Trimatic in my VK (300hp) with stage 2 shift kit & 2500rpm stall.
    Vk calias
    Aug 2006
    Yea I though about the turbo 700 but then i would have to adapt it to the block. Im trying to do the whole convertion for under 2500 so dont have much left over for the auto. O well looks like i'll chuch the supra box i have in.
    Hows yours to drive with the auto phantom?
    Do you have any problems with trans heat?
    How is it on fuel?
    Does you motor supply enough vacum for changes?
    VK Commodore
    Sep 2006
    Yeah it drives really good. I'm gunna put in a VL turbo diff to drop it down to 3.45 ratio
    I've got a fairly large PWR trans cooler so it stays fairly cool.
    It's running rich at the moment - still sorting out the tune. It uses about
    20l/100km on the highway.
    No worries with the vacuum, plenty there.
    the lightning
    Jun 2005
    under the Southern Cross
    the trimatic I'm running in mine I'm told is good for about 450HP at the flywheel, anything more would require a lot of stronger internals hardened gears etc. its a 2500 TCE hi Stall, Full manual valve body so vacuum for shifts isnt an issue, it shifts hard, like a stage 2 shiftkit would i guess. Talk to Trade Matics in Geelong if your in VIC he built mine had it a couple of years now and it takes a bit of punishment although nowhere near 450HP...
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i've had a standard traumatic behind a brocky modified 308 for years and it's handled the abuse ok, bands need some adjustment but thats about it really. been driven hard for many years with an engine producing easily around the 180 + kw etc. my only complaint has been the converter which is way to small for the application causing issues with the engine stalling at idle if it's less then about 1000rpm when dropping into gear etc
    Body by Holden, Soul by Brock
    the Legend will live forever
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by Cane_It View Post
    Nice
    Good take off?
    Trans cooler?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    the lightning
    Jun 2005
    definitely running a trans cooler, you have to, and bypassing the plumbing into radiator. doesnt launch too well, tends to sit there spinning the wheel (only a 3.08 single spinner in it atm), but good when it hooks up, easily chirps the tyres from 3500rpm upwards into second...
    Goon's Avatar
    Feb 2006
    GC. QLD
    Nice, mine spins up until 20, i use 2nd once it kicks in past 25k and go upto 70k, pull over 2000rpm for sure probley close to 2,5.. extractors get used
    I'm still looking at a 5speed myself but that upgrade sounds sweet
    vk_calais5.0's Avatar
    vk_calais5.0 is offline Jealous of Project VEE EL
    VY Berlina v6(daily)VK Calais 5.0(sold)
    Sep 2006
    Tanunda
    i think i need a trans cooler by the sounds of it,considering i have vl turbo rear
    and stage2 kitted trimatic. i think it should launch harder than it does
    still chirps into second..
    the lightning
    Jun 2005
    the trans cooler will help your oil, ever smelt how rotten the stuff is if its been cooked...
    definitely run a seperate trans cooler with a modded trimatic, bypass the radiator as all you're doing is adding 90'c heat into the trans fluid from the coolant.... you'll find your trans will like it a bit better.
    vk_calais5.0 - is your 5L stock or have you upped the ante on it? would be curious with regards to how yours launches. suspension has a lot to do with it to. my suspension is shot, thats next on the list of big things to do.
    Goon, I had a similarly modded tri behind a fairly heavily modded 202 in a torana, did awesome chipys in that too but i had to get the revs up to 4000rpm+, anywhere between 4000 and 6000.... easily smoked N/A VLs and based on comparitive dyno figures of VLs and VNs I'd say it would have flogged a VN 3.8 auto, probably not a 3.8 manual though unless it was driven by a retard that wouldnt be able to keep it straight.
    Vk calias
    Aug 2006
    Well if anyone is interested in swapping a fully manualised trimatic with 3k + stall for a w57 supra 5 spd with EVERYTHING you will need to drop it into a vk let me know
  15. #15
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by ported View Post
    Do u get diff rpm ratio's? with that box?
  16. #16
    Vk calias
    Aug 2006
    Quote Originally Posted by Goon View Post
    Actually after looking at this I remember its either a w55 or w59 its has a very low first gear so leaning towards w59
    this shoould tell you everything you need to know (page 6)
    http://www.dellowauto.com.au/catalog...Automotive.pdf
  1. EFI 202 and Trimatic
    By BowTieGQ in forum Parts And Other Items For Sale
    Last Post: 08-02-2007, 07:22 PM
  2. 308 trimatic
    By NUT74 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-10-2005, 04:20 PM
  3. Trimatic
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-09-2005, 08:51 PM
  4. V6 On To Trimatic
    By SLIPPERY PIZZA in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2005, 07:59 PM
  5. V8 Trimatic
    By davway in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-11-2003, 05:50 PM
