Results 1 to 4 of 4
Thread: drivers side window stuck
    VK calais 4.9lt
    May 2005
    Default drivers side window stuck
    hi can anyone tell if my power window motor is stuffed on my vk bought a new cetre console switch because the back ones were stuffed then the drivers side started to go then stopped all together now with the new switch they all work fine but drivers side still wont budge help me please
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Pull off your door trim, unplug the window motor and apply 12+ & 12- to the terminals and see if it moves. Reverse the polarity to make it go the other way. If it wont move odds are its stuffed.
    cheers
    Scott
    kellyvk's Avatar
    kellyvk is offline kellyvk
    vk calais 5L/ vk commodore 6
    Apr 2007
    sydney
    Quote Originally Posted by azza009 View Post
    You can get a new motor for the drivers door from a wreckers. My passenger window only worked on a stinking hot day, when it got cold it wouldn't work so i just stopped using it. I never took passengers in it
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    If you do replace the window motor make sure you buy the correct one, the series 1 regulators VB-84VK are diecast where as the 85VK & VL are pressed steel the motors are not interchangable. however you can fit a later model regulator and motor and it will work just fine if not better.
    cheers
    Scott
  1. Drivers side window problem
    By onthepony in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2008, 07:03 PM
  2. Drivers side window part.
    By epoxpro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2007, 08:19 PM
  3. Fitting drivers side window
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 01:34 PM
  4. drivers side rear window
    By david41073 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2005, 10:03 PM
  5. VT - Drivers side Window Issue...
    By bradwilks80 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2005, 11:39 PM
