as the title says, how much power do they have??
We got rep back, yaaay!
around the 100kw mark.
know an exact figure?
i thought it was around there but i would like exact specs if possible.
100kW with single exhaust(at 4200rpm), 115kW with dual exhaust(at 4400rpm)
Holden Blue 4.2L V8
Capacity: 4.2L
Induction: carburetor (Quadrajet 4-barrel)
Valvetrain: overhead valves, 2 valves / cylinder
Bore x Stroke (mm): 92.075 x 77.775
Compression Ratio: 9.0:1
Maximum Power: 100kW @ 4200rpm with standard single exhaust, 115kW @ 4400rpm with twin exhaust option
Maximum Torque: 269Nm @ 2000rpm with standard single exhaust, 289Nm @ 3200rpm with twin exhaust option
thanks to the both of you, helped me out heaps, just one final question 2.5" straight through single would make a gain of what?
Well, new condition 100kw but with the age of a blue 253 maybe now around 85/90? And a single exh around +4/5kw
engines only done 30k since rebuilt so it should be pretty close to 100kw, thanks slundy!
see if you can grab one of the holden option dual exhausts. i got one for about $100, made it sound a bit better and there was a noticable power increase. only problem is you move you peak torque up 1200rpm and that is especially noticable if you have a 2.78 diff.
if you were to get extractors and join them to the twin pipes youd get a bit more power there too.
how do you think it would sound if i got the extractors on the 2.5" single system i have now?
mines doesn't really sound beasty until you hit 4 grand
but ive driven kingswood 253's that sound killer stock!
That would be a good set up mate, grap some tri-y's they are good for low down power and are reasonably cheap. I run tri-y's into twin 2.5 inch pipes with straight through mufflers on my z and ive got an awsome note right up to the rev limiter at 7k.
sweet, cheers slundy and btw 253's go up to 7grand!?!
i dont take mine past 5500 as per tacho redline.
what work have u done?
The engine was rebuilt (from what ive been told) with acl race series flat tops and acl bearings and arp bolts (but otherwise stock) before i got it, ive cleaned up the heads with new valve springs (no major porting), cam (216/226 @ .050 with 112 deg lobe seperation) double row t/chain, single plane manifold (ported and polished), 600 holley with braided fuel lines and h/v fuel pump, jp oil pump, gilmer drives, twin thermos, msd pro billet dizzy/msd 6al ignition/msd coil with custom leads. i think thats it..... with a toyota 5 speed and 3.08 lsd.
600 will be going soon for a 465. 600 is only good in the upper revs, no good down low.
its quicker than most 304 commodores neways so its gotta be making a bit of power.
sounds like it! good job!
The cam change was the best mod ive done. it is far easier than you would think plus it gave me heaps more power, a way way nicer exhaust note and idle and would you belive much better economy. it ended up costing me around $500 so not that expensive either.
thats what i was planning on next, that and extractors. and rego![]()
Yeah thats a good idea mate. hold off on the cam if your trying to get it licenced, they dont like cars that wont idle......
nah just gotta get it registered ran out 2 months ago and atm i have a serious cash flow problem
