Have a few questions about VK Calais's, did all of them come out with electric windows? One I'm looking at doesn't, but it has all other Calais features.. Also, whats the deal with the electric dashes, are problems with them fixable? This one, when gettin up to high revs it will cut out, then when in the next gear will come back on again.
Cheeeers for ya help
Cheers, Gaz
the digital dashes are fixable for most part, would prob cost around $250 depending what they find, they can do em in the car or you can give em the dash normally. Dont know who you'd get to do it in Adelaide, try ringing VDO first and see if they can help you or point you in the right direction. I think there were a few VK calais that didnt have the electric windows but not too many.
yes VK Calais were standard with power windows, however they could be optioned 'off' I have seen a couple like this.
Dash problems are usually at the sender/sensor rather than at the dash, in my experience.
Check the compliance plate if your not sure its a real Calais, the 'Model' code should start with a 3 after the dash - for Calais. IE a Calais with a 6 & auto should read 'xxxxxxx - 323' a 5l Calais would have '333'
thanks i would assume it would be something semi straight forward
buti will let the professionals look at,they giving me a free quote
