Hey guys a guy I know gave me an electronic fuel pump and webber carbie off an XF falcon. The pump is almost brand new and its suited to carbie XF falcon.
Would it be good to bolt onto my 202 now and put the carbie on later when i get the adapter plate?
I reckon it'd be ok as its a carbie pump.
As long as you had the pressure regulator and the return line hooked up it should work.
It doesnt have a regulator so i would need one?
The XF it came off would have had one, see if you can get it off that.
His xf ute has just been converted to e series motor. Maybe the pump is aftermarket i dont know if xf's had electronic pumps standard.
