Hey guys just wanted to know if a tailshaft from a VB wagon will fit a VB sedan.
I'm pretty sure it will as they are the same wheel base. It wasn't until the VN that the wagon was longer.
Cheers for that champ,already been thorugh 2 tail shafts and need another one,Kept ****in the centre bearings on em finally figured out the problem which was 3 bolts missing from the engine mount which ****ed everything outa line.
Also does anyone know some cheap mods i can do to it, its just a thrash around car manual 4.2 ltr.
Cheers for your help
Extractors, 2 1/2" single system, 4 barrel varijet with vacuum secondaries. Not real cheap though, around $1000. Try your luck at some wreckers, they may have the exhaust and carby. A tip, all extractors from VB-VK are the same. All exhausts from VB-VK sedans will fit.
Ok the wagon has a tail shaft that is 8" longer then the sedan so u will have problems i have cheeked my book and thats what is says
Ok thanx for that mate![]()
