Results 1 to 6 of 6
Thread: lpg not working
    83 VH slx
    Oct 2006
    Adelaide Sa
    Default lpg not working
    hey hows it going?
    ok well heres the deal..
    my old baby died. and i took it to a mechanic.. got EVERYTHING DONE. cost a fair bit,
    the car runs beautifuly now, and starts on fuel without any proglames ( its on lpg ) but it will not now start on lpg...
    any suggestions? all i can hear is it turning over. was low on gas, so filled the tank, but still nothing..
    Vk calias
    Aug 2006
    maybee the realay to the gas shut off soliniod or the solinoid itself. Or I have to ask did you check whether the gas is turned on at the tank? The mechanic may have turned the valve off
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I don't like the idea of people playing with LPG unless they are damn sure they know what they are doing, but anyway...
    I assume your car is dual fuel.
    Get a mate to help you.
    Remove the large gas hose which is held by a clamp connected on top of the mixer. The mixer is where the air cleaner is mounted on top of the carby. Switch to gas and crank the motor and you should get a good flow of gas coming out of the hose. If you get some gas then good.
    Make sure that there is plenty of coolant/water in the radiator (full) and that the overflow tank is half full. The converter will freeze if there is no water flowing through it which will prevent gas vapour entering the mixer.
    Also check that the lpg safety switch is functioning. It looks like a small black box with about 5 wires coming out of it. They usually have a LED on it as an indication. It should display when cranking or when the motor is running.
    Check the gas tank valve is fully open.
    Make sure the mixer is sitting firm on the carby.
    Check these things.
    the lightning
    Jun 2005
    under the Southern Cross
    check all the above and also the 10amp fuse that is part of the LPG electrical circuit, usually jammed under the fusepanel in VK, not sure where it is on a VH, location probably also varies with who installed the gas system.
    also crank the motor and get a mate to check that both the tank solenoid and the solenoid just prior to the converter (on the high pressure side) are opened when the motor cranks... use a test light...
    good luck
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    The fuse might be located under the dash where you would see the switch. Mine is there and it's an inline fuse holder.
    83 VH slx
    Oct 2006
    Adelaide Sa
    cheers for the input guys, its working fine now.
    me and a mate played around with it, dissconected and reconected, and it worked.
    guess it was just connected poorly in bits and pieces.
    missed those cheep fumes.
    thanks
  1. Fan not working
    By Old fart in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2009, 05:50 PM
  2. Fan not working at all
    By stumps5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2006, 01:25 PM
  3. Fan not working on VN
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-04-2006, 01:20 AM
  4. Working a 202
    By macdooby in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-11-2005, 02:14 PM
  5. VK Fan not working
    By Kevin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-02-2005, 04:41 PM
