Results 1 to 11 of 11
Thread: converting vh slx 4.2 auto to manual
    vh slx 4.2
    Apr 2007
    Default converting vh slx 4.2 auto to manual
    Hi there, im new to this forum . Bit of an LC GTR nut but have a soft spot for the vh v8's, owned an x cop vh 308 with all the brock eng trimmings, lsd etc then i got married and had to sell!
    Im about to buy a vh 4.2 SLX auto and want to change over to a manual.
    Is the pedal setup out of a vb-vh the same in the 6's & 8's?
    At this stage i'll go for the m20/21 just to get me running with a manual but will definitely look at putting in a supra 5spd or holden equivalent.
    Any thought and suggestions on the mods would be appreciated.
    Kev
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yes the opedal boxes are the same. Just remember that things like tailshaft are needed and a spigot bush
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    The pedal set ups are different between 6 and a V8. Its something to do with the pedal pressure, using a 6 cylinder one wouldn't feel right.
    Also Pub24/7 if he uses a Opel gearbox, it wouldn't bolt up to the bellhousing or motor. Also a very weak gearbox. I think he means the Australian design and built M20/M21, aussie 4 speed. These are different, the M21 a more closer ratio than the M20. Also the M20 is really designed for 6 cylinders/stock253s. The M21 more a heavy duty box designed for more higher output 253/308s.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Your right sl/e nut i didnt read it right trust me not to read it properly. Though i did not know the pedal boxes were different i thought they were all the same they look very much alike
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Yeah, the pedal boxes are different. I thought they were the same but after looking at dads VB 6 cylinder and my 5.0L VB i did see the difference.
    Thats a V8 clutch pedal set up
    Thats a 6 cylinder one. Have a look at the hook deatil
    vh slx 4.2
    Apr 2007
    thats exactly the info i needed.
    A couple of wreckers are telling me they should be the same but the exploded view confirms the difference.
    The box will be an aussie 4spd for now.
    With more and more vn vp 5spds appearing are they a better option as 5 spd replacement rather than the supra?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    The problem with the VN-VS T5 5 speed gearboxes, is that the bellhousing are a turbo bolt patten, a 253 are an aussie/trimatic bolt patten. You can buy a new bellhousing for the T5 to bolt into your 253. Same deal for the Supra 5 speed too.
    vh slx 4.2
    Apr 2007
    I'll be changing to a 308 so which is the better option supra or T5?
    Also with supra's do the shifters all end in the same position on box or do they vary ie w57, 58 etc?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    I don't know about the Supras, never seen one in detail. Best thing to do is ask a gearbox specialists, they could know the difference.
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    ive heard that even the n/a supra box is stronger than the T5 so that would be a better option
    We got rep back, yaaay!
    VH SL/E 308 and VY II 25th Anniversary
    Jan 2007
    From experience, the Supra box is a pretty tough cookie, and i think might be slightly easier to get hold of than the T5. I've heard the Supra box teamed with a 308 is a mint combination, probably the best bet but it's personal choice really. I'm still using me trusted old trimatic!!!
    "If in doubt, increase emphasis"
  1. Converting V6 Auto to Manual on VS???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-05-2012, 10:05 PM
  2. converting vh slx 4.2 auto to manual
    By gtr161s in forum VB - VC - VH - VK
    Last Post: 02-05-2007, 06:51 PM
  3. Converting an auto to manual.
    By Fitzy3VSVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2006, 01:31 AM
  4. Converting Auto to Manual
    By Ute2004 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-03-2006, 04:52 PM
  5. converting VP auto to manual
    By mattbiggs01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2005, 06:57 PM
