Results 1 to 7 of 7
Thread: My car hates unleaded
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Default My car hates unleaded
    Well the other morning i ran out of petrol before i even got out of my driveway. (got a dodgy sender unit) Anyway my car is normally good on the juice but since ive rebuilt it it obviously using more.
    My problem is im running late for work so i fill her up with a whole tank of unleaded. Stupid move its pinging of its nut everywhere basically its almost undrivable. I dont want to waste a tank of petrol or spend 10 on so called octane booster. Should i just retard the timing to help stop a lot of pinging?
    The reason for it is compression its prolly a lot higher than expected and ive only ever really ran pulp since i rebuilt it
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    VK Calais EFI
    Apr 2007
    If you don't need to nail it, disconnecting the vacuum advace will retard the ignition timing at low loads, and when you get good fuel, you can just reconnect it and not worry about a timing light.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    You should look into getting a water injection system to stop it pinging. You might be able to get away with running the cheaper unleaded all the time. You used to be able to buy cheap systems that looked like a windscreen washer bottle for the water and a small plastic hose that went to your carby just above the throttle butterflys. Some of the old stromberg carbys had to have a hole drilled and tapped into them for the water injection, but with some of the later carbys you should be able to use one of the vaccum fittings that is already on the carby. Adding a bit of metho to the water helps also.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Considering the 202 was designed to run on 96 octane Super, trying to run it on 91 octane fuel no doubt it would ping. It should be run on either 96 or 98 octane unleaded.
    cheers
    scott
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeah i know i have always used pulp until this week i was late for work and didnt want to waste time going somewhere else. the water injection although a good idea i will be going efi soon so it not really an issue thanks anyway guys. Also when i finish rebuilding my yella terra head it'll will going back on with a decomp. gasket as this 173 head is killing me
  1. unleaded or premium unleaded
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2007, 08:27 AM
  2. Unleaded or Premiuim
    By Thorney_86_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-07-2006, 10:20 PM
  3. Unleaded vs Premium unleaded
    By Vanna in forum General
    Last Post: 09-05-2006, 05:43 PM
  4. The Easter bunnyy hates u
    By CALAIS 6 in forum Jokes/Humour
    Last Post: 14-04-2006, 01:58 PM
  5. Unleaded v Premium Unleaded
    By TCS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2004, 03:48 PM
