Results 1 to 11 of 11
Thread: Starter problems
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Default Starter problems
    I finally got a battery into the vk on the weekend. The windscreen wipers, indicators and taillights work, but the starter won't!!!
    There were some wires hanging around near the starter motor. I traced them back through the dash to a switch hanging by the steering column. The ignition barrel is smashed up, so i'm assuming that the switch was used to start the car. There is a tan or purple(it is dirty as) wire and a light blue wire.
    I've talked to the person i got the car off, but they bought it in a non running condition, so aren't sure what the go is. It was apparently running when they got it.
    Here is a dodgy photo i took with my dodgy phone.
    I think the top lug links to the starter motor. The blue wire is just hanging, and i did try hooking it up to where the thin red wire goes onto the spade connector. I think the tan or purple wire is attached to the lowest terminal.
    What else should i hook up, or what can i short out with a s screwdriver to get it to kick over?
    ECOTEC KICKED IN yO!!!!!!
    the lightning
    Jun 2005
    under the Southern Cross
    to kick it over bridge the solenoid terminal to the heavy power post on the starter with a heavy screwdriver with a decent handle....
    May 2004
    darwin
    i think i tried that. nothing. i'm guessing the starter is dead. i used a test light and had power at the big post and the spade conector but nothing.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    tryed pulling it out and connecting to a power source then give it an earth source and see if it spins ?
    id do better connections though or try replacing the wires, looks like a shabby job..
    if still on luck replace it...
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    May 2004
    darwin
    Quote Originally Posted by Goon View Post
    trying to avoid pulling it out, as i think that involves pulling the manifolds off. it was a pain getting them in!!!
    I was watching a mate working on his escort on the weekend, and that has a bosch starter in it. He had the wires hooked up but it didn't work. He then remembered that the spade connector was on the wrong terminal and moved it to a lower one on the solenoid. could the 202 be the same?
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I have seen some starter motor solenoids with up to 3 spade connectors. Some I have seen have two only connected and one that does nothing. Have a look at it you'll see if there is any connection.
    the lightning
    Jun 2005
    take the spade off the terminal and bridge to the heavy post with a screwdriver, if you get no action there then the solenoid is stuffed.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by Cane_It View Post
    kinda sounds like the time i tested my coil.. it worked to "zap"
    May 2004
    darwin
    well, whattaya know. there was another spade connector directly below the one i was trying to use. i have some heavier guage wire going from the nut terminal to a momentary toggle switch and then onto the lower spade connector. and it works. i hadn't seen it turn over since i got it about 6 months ago, so had no idea if the motor was any good or not. it didn't have a carby or distributor so i transferred them from my old vh. now i know it works i'll get it all tidied up and go racing.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by vh-holden View Post
    good luck mate
    May 2004
    darwin
    and i've just found a freebie wagon. that will get me some windows
  1. starter
    By Burnout_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2007, 10:51 PM
  2. Starter, Coil, Soliniod PROBLEMS
    By Shane1989 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-11-2006, 02:35 PM
  3. VK starter problems urgent!!
    By palmsvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-06-2006, 03:21 PM
  4. starter motor problems
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2005, 10:04 PM
  5. starter and tail shaft problems
    By micky69 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-04-2005, 06:26 PM
