ok well last night alot of my lighting went to the crapper.
the first problame was i was on delivery ( im a driver. ) and i noticed when i trod on the braked, my left indicator on my dash lights would glow, not light up, but more of a half way there type of thing.
then i noticed when i was on the brake and tryed to indcate left, it wouldnt, or it would but at a very slow rate.
so i got pulled over, need to re-do my whole left hand side back lights for me to pass the defect.
so i was thinking the indicater problame could be a earth problame? could anyone please tell me where i would find the earth on my back lights, cant seem to find the bloody thing.
also, any idea why when i brake it is interfering with how my rear lights react? i cant figure it out, im broke so i cant go to a auto election and ive got till tuesday to clear it (Y)
thanks for your help.
Have a look and clean the earth points on the back, where the tailights bolt into, in the boot. Also clean the contacts on the actual tailights too.
i had exactly the same problem not 2 days ago! your right it is an earthing prob, check the plug-in connection to the left hand rear tail light assembly, and look for a burnt earth pin (ill post some pics) i gave em a good clean up with some 'wet and dry' but the prob came back shortly after so i said stuff it and soldered it together, has worked a treat so far also stopped the brake lights on that side dimming when the indicator flashes
hope this helps
ok thanks for the advice.
but i cleaned the conenctions and the earth conencting bits and pieces, and it didnt change.
for now ive got one last question
the for a while my two middle rear lights have not worked.
theres the two lights with the indicator and one rear light on either side, but you know the two in the middle? two new blocks of lights, so four lights all together?
well anyway these two middle sets of lights havnt worked in a while. one reason was they had no globes. i bought some globes, but they still dont light up, and idea?
and do these two blocks of lights in the middle have an earth? cos i couldnt find any on either.
thanks, need this fixed asap or i cant work.. *sigh*
the 2 midd;e ones should only light up when you brake. It does sound like an earth problem
i had the same problem wen i had my vk i just sprayed sum wd-40 on the connections and they work..
Run a wire to earth from one of the earths on the light socket and see if that helps. It fixed my problem.
mine does the same thing, but on the right side instead, just corroded contacts on the plug for me, and for the center lights not working could be that only certain models used them, check to see if there is a terminal in the bottom of the bulb socket
Hey mate when u gonna post a pic of ur car with my old mags.....I really wanna see them on there.....I loved those mags...didn't wanna sell them but had to sacrifice them to get my 17's.![]()
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
i believe VHPirie had this problem with the lights cracking the poops but it was just an earth problem. when i got my car the right indecator flashed heaps quick, i wired up a trailer plug soon after and when we had a trailer on the back the indecator went normal again but i didnt worry about fixing it tho coz i fitted the vk tail lights so therefore had to chop out the old tail light loom and had to put a vk one in. i threw in an extra earth just to be sure and it works great.
u shud just get some wire and dodge up a few earths for it and see if it helps then do em properly.
a mate had the same problem with his vc commodore, so i just did the easy thing and cut the old loom out and made a new one up, havent had a problem since and it is alot tidier than the loom that was in it. only took an hr or so from start to finish.
