Results 1 to 13 of 13
Thread: auto to manual problems - need help urgently
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Default auto to manual problems - need help urgently
    hey everyone, finally did my manual conversion.. after alot of headaches the gearbox is finally in.. but now it wont start..
    we found out the problem is the spark pick up thing.. its a sensor that goes into a hole in the automatic bell housing, and picks up a point on the flywheel and tells the coil when to spark??? thats what ive been told.
    my problem is that there is no point on the manual bell housing for the sensor to slide into.
    to get around this can i change my ignition setup the the electronic dizzy off a blue motor? cause i really dont want to pull my gearbox out again it was hard enough putting it in.
    if so - what are the steps involved in changing from the EST to the electronic dizzy.. is it as simple as unbolting the est dizzy and bolting in an electronic one?
    any help appreciated. thanks
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    i got an electric dizi here and can put it in, but ive used enough fuel going to and from urs :P so ill bring it next weekend unless you want it done before then
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    how the hell does the manual system work normally if there isnt a point for it to go in then????
    You need to find out how the manaul motor works then follow that! do you have a manual?
    Sorry, i have no ideas about how VK's work...
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    1982 VH SL/X 6cyl 4spd, soon to be a Mild 253
    Oct 2005
    Port Pirie, South Aust
    not sure if it would be the same sorta thing (prolly not) but i converted my efi auto to a manny tranny and theres sposed to be a wire going to the auto box to tell the computer something but as the manual dont have it we just threw it on the starter motor and it started first go, no dramas (except for sum doofus forgot to put a hose clamp on the fuel line haha)
    im sure me bro's about to prove me wrong
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by PEAKN6 View Post
    ur a ******** The wire we connected to the starter was the neautral safety switch.....the wire ur thinkin of wasn't even in ur car.....it was my wags u saw that on lol....and it's like a crank angle sensor thing I rekon....just bullshiit for the EST
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    When I done this, I had the same problem.
    All I done was drill a hole into the housing.
    However this was done when the gearbox was out of the car to make sure it was in the right position.
    Do you also have a flywheel with the 3 pins in it? It was difficult to find one for me.
    Feb 2006
    Radelaide
    nope dont have a flywheel with the pins, i want to get rid of the EST, can i just put an electronic dizzy on and be done with it?
    dreamcatchu's Avatar
    dreamcatchu is offline sick puppy
    VC Commodore
    Sep 2004
    Bundaberg qld
    yep, theres no probs in doing that, asfar as i know you just have to bypass the est crap, ooh and hook up ur vacuum advance
    VN/VT
    Sep 2005
    SA
    Feb 2006
    Radelaide
    Feb 2006
    Radelaide
    what wires go where, i have a green wire and an orangy pinky tan'y one... ive connected the oranghy one to the positive side of the coil and the green one to the negative and it still wont start? any ideas have i got it wired up wrong? thanks in advance
    VC Commodore
    Sep 2004
    Bundaberg qld
    you wired it up right cos thats how mine is. did u change your coil? as from memory the est and hei run different coils, or you could always just run some power to your coil straight from the battery to see if it's a wiring fault elsewere
    Feb 2006
    Radelaide
    ok its running now thanks for the help everyone.. the wires coming out of the dizzy were twisted together and were arcing out and not letting it spark so i changed the wires and now its running.. running rough but good enough for now
  1. urgently needed auto - manual vs wiring diagram
    By micvs in forum Electrical Wiring / Questions
    Last Post: 14-01-2007, 07:41 PM
  2. First Problems Auto - Manual
    By Mr Robbo - The General in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2006, 02:38 PM
  3. VP Manual Problems
    By hound in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 11:52 AM
  4. Problems with Manual
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2005, 08:24 AM
  5. VT 5speed manual problems
    By yeggles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2005, 09:48 AM
