Results 1 to 5 of 5
Thread: vc wiper motor
    2007 VE SS
    Nov 2006
    Default vc wiper motor
    hey guys... anyone know how to get a vc wiper motor out ?? its right there under the hood but i just cant seem to find the way to get the bastard out.. do i have to take the dash out?... any help much appreciated.. =]
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    They are a bugger to get out. You don't need to get the dash out.
    Undo the wire connections.
    What you need to do is take out the whole windsheild wiper assembly.
    So if you have taken off the wiper arms, undone the plastic nuts that are on the bit the wiper arms go onto then you push on them to push though the holes. Then its just a matter of pulling, twisting and a hint of swearing and it should be out.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Exactly as SL/ENUT said above....but it was easy to get mine out....I pulled mine out of the VK the other day and it was only like a 5-10 min job.
    1982 VH SL/X 6cyl 4spd, soon to be a Mild 253
    Oct 2005
    yea getting it out is the easy bit, getting the sucka back in there could be a bit tricky. good luck with it tho.
    2007 VE SS
    Nov 2006
    thanks very much for that guys .. worked a treat...
  1. Windscreen wiper motor issues
    By andrewmac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2006, 05:40 PM
  2. rear wiper motor
    By shae in forum Electrical Wiring / Questions
    Last Post: 20-06-2006, 02:56 PM
  3. Windscreen wiper motor
    By huwbacca in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 05:17 PM
  4. Wiper Motor Stuffed?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 10:17 PM
  5. changing wiper motor...
    By Coxy_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2006, 06:05 PM
