Results 1 to 6 of 6
Thread: red 253 crankshaft rotation
    VH commodore SL wagon 253
    May 2006
    the shire sydney
    Default red 253 crankshaft rotation
    Wondering which way to crack the crankshaft pulley nut so i can get to the timing chain and camshaft? Standing at the front of the motor i was belting the crap out of the nut with a special breaker tool i took from work in a counter clockwise direction... keep whacking it this way? or whack it in the other direction for a left handed thread? thanks guys
    Achin' for a v8 wagon people click me!
    the lightning
    Jun 2005
    under the Southern Cross
    anti clockwise like you would a normal bolt...
    stick an obstruction like a metal bar into no 1 sparkplug hole and allow it rest on the piston, then gently and smoothly!! undo the bolt with the breaker bar... the piston will rest on the obstruction without doing any damage if you are gentle. I use a 2ft long bit of 1/2" steel pipe that I slip over the breaker bar, giving me about 2.5ft of leverage which will be plenty to undo it... I got the bit of pipe from bunnings...
    May 2006
    the shire sydney
    the tool i have is a pretty forceful beast i wouldnt like to have anything near the pistons when using it. its a long bar with a short swivel piece on the bottom whack the long bar down and the swivel rotates a short sharp distance. but it still wont bubge... ill get a breaker bar and use some exhaust pipe on the end maybe to break it...
    the lightning
    Jun 2005
    you need to be able to lock the crank from rotating for you to be able to get that bolt free, they are torqued up VERY VERY tight... ie my manual says 190Nm MINIMUM and they are loctited in aswell, sometimes a touch with the oxy will help... I've replaced one before on a 308 on a stand and lets say that I really had to lean on it, and I've done one in the car that was easier as the motor is held properly and I have a cam dialling in tool that screws into the spark plug hole that I also use for this purpose.
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by Cane_It View Post
    Best not to ever do that, youll crack the piston. pull the radiator out and use a rattle gun. it'll save you a lot of screwing around.
    May 2006
    the shire sydney
    yeah i got it wedged a hammer through the flexplate and then breaker bar onthe nut with a long as piece of exhuast on the breaker bar... i'm 95ish kg i got it pretty easy... doin it back up later is the challenge!
  1. crankshaft pully vp-vs
    By projectvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 10:57 PM
  2. crankshaft sensor
    By im blonde? in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2007, 01:52 AM
  3. TYRES [rotation >]
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2006, 03:18 PM
  4. Now that's a Crankshaft!
    By IanG in forum The Pub
    Last Post: 06-05-2006, 10:50 PM
  5. Need Vs Vt Crankshaft
    By ADZ124 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-05-2006, 09:26 PM
