Results 1 to 6 of 6
Thread: V8 differences
    VH SL/X
    Apr 2006
    Brisbane, Queensland
    Default V8 differences
    What is the difference between the red & blue 253's?
    And also the difference between the red and blue 308's?
    Thanks,
    Matt
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Red 253s: They use a 2 barrel Stromberg carbi, basic emissions. Mechanical points dizzy
    Blue 253s: Use a 4 barrel Rochester, better emissions. Also a bit more power. HEI, High Energy Ignition dizzy, other words electric.
    Now the bigger brothers.
    Red 308s: Like the red 253, basic emissions. Not much power with a single exhuast. Also has mechanical points dizzy
    Blue 308s: More friendly with the emissions, HEI, bit more HP at the flywheel. Not much difference between the red 308s.
    VH SL/X
    Apr 2006
    Thanks for that. A couple of other things....
    Was there anything internally difference with the red vs blue V8's? Like, will red 308 heads bolt onto a blue 308 block, etc? Was there larger or more ports, like the red vs blue 202's?
    Thanks,
    Matt
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Blue heads will fit onto a red 253/308. But i don't thinking red heads fit onto a blue 253/308.
    The ports are the same in both heads, unless its a B cast or "X" heads.
    vk383
    Sep 2005
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    X heads are the same as a B cast, just doesn't have the B cast on them. They were made just before the B cast heads.
  1. What are the differences VN SS and VP SS?
    By willygrice in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2007, 06:26 PM
  2. VX differences
    By zohpm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2007, 10:35 AM
  3. differences in vn v6 and v8
    By ashzv6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2007, 02:28 PM
  4. V8 differences
    By bangers in forum General
    Last Post: 20-06-2006, 02:12 PM
  5. vs/vr differences
    By sarj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2005, 12:32 AM
