Results 1 to 10 of 10
Thread: 5L into VK
    Oct 2005
    Default 5L into VK
    Ok, im wanting to put a VN-VR-VS 5L V8 into a VK. Now i have a few questions:
    1) Will the engine bolt straight in the car? If not then what work is required?
    2) Will i need to consult an engineer to approve the conversion, seeing as the car originally had a V8 in it?
    Cheers,
    Timo
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    First off, whats in the VK now (you said originally, meaning its changed)? If its not a V8, you'll need a V8 cross member.
    I guess you'll be using the standard VN-S trans aswell, you'll need to redrill some holes, and make a bracket for the gearbox.
    You WILL need an engineers report, as you are putting a motor in a car that didn't originally have it. This is the same even if your are putting a VP 5L into a VN (stupid, but what law isn't)
    You'll need to add all the pollution equipment, aswell as an exhaust with cat converters.
    The list could go on for miles tho
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    What Stealthy said except the requirement for an engineers cert will vary depending on what state the car will be registered in.
    Reaper
    STEALTHY™'s Avatar
    Jan 2005
    I would really consult an engineer either way, as you'll also need to upgrade the brakes (to 4 wheel disc at a minimum if it doesn't already have them)
    cheers sexy
    Oct 2005
    Yeah the cars got an 8 in it already, just the stock one. So what your saying is that the engine will bolt straight in but the trans will need some work to fit? This is no problem as i can do all this myself pretty easily.
    I was going to fit discs alround anyway so brakes are no dramas either.
    So on the whole it sounds like a pretty easy conversion, has anyone on here done it?
    Also it wouldnt be too hard to get an engineers certificate for a swap like this would it? Sorry i have no experience with engineering approvals lol.
    Theres no clearance problems with steering rack, master cylinder or brake booster etc?
    Thanks guys for your help so far.
    Cheers,
    Timo
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    I thought all V8 VK's came out with 4 wheel disc brakes. Correct me if i'm wrong.
    Cheers Tom
    Oct 2005
    Quote Originally Posted by Tom_1569 View Post
    Cheers Tom
    Tom your right, bad choice of words on my part. What i meant was upgrade discs all round.
    Cheers,
    Timo
    STEALTHY™'s Avatar
    Jan 2005
    I couldn't really help with anything else, my conversion was a V6 and 5 speed into a VK Wagon. We made a custom gearbox mount, but its fairly easy once you have it in there what needs to be done.
    You main problem getting an engineering certificate will be pollution gear etc.
    Your best be would be to ring an engineer and speak to them directly. I have ADRs of what needs to be changed when it comes to different motors etc, but having a brief look through, i couldn't find the exact page again.
    I'm not sure on the mountings for the VKs, but i would assume the VN gearbox auto or manual would be in a different position (with mine the shifter was about 40mm back, and hit on the centre console)
    cheers sexy
    VH SLE
    Aug 2007
    Hi Timo,
    Check out VK Berlinas web site its very helpfull and it gives you ideas.
    VK Berlina Project
    Oct 2005
    Cheers champ
