Results 1 to 19 of 19
Thread: Weak VB!
    VB 79 2.85
    Jan 2005
    Melbourne-Eastern Burbs
    Default Weak VB!
    Hey people, Im new here!
    The names kyle and ive had my VB for about a year, i bought it for $1000 with 115,000 on the clock, some paintwork damage, and the 2.85lt, 179 motor i think it is.
    After i pay a few bills, im considering making it go faster to tell those people who say "get a f*rd" where to go.
    I'd love a v8, but im quite keen on keeping the engine thats in it at the moment, and seeing what i can get out of it.
    Any ideas on what i could do to it would be awesome
    Cheers guys
    Kman
    Yeh i know my VB is weak
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Well the motor isn't a 179 but a 173.I don't how a 350 holley would go but a port and polish of the head would make it go a little better.A 2 inch sports zorst with extractors too.But first whats your budget?.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I'd say take it back to the pub, maybe you got a bad batch and they should exchange it for a new carton for you. Best of luck
    Torana's Avatar
    Torana is offline Young Einstein
    KE Laser Ghia 1.6 Carbie M5
    Oct 2004
    Meadowbank, Sydney, NSW
    VS Exec Series II
    Jan 2005
    Ringwood, VIC
    VB 79 2.85
    Jan 2005
    budget - not really caring about that at the moment, but after ive payed a few bills then i can splash my cash.
    I was wanting to paint it green and turn the boot into an esky, but decided engine mods would be nicer!
    Pity they didnt call it a Holden Carlton Draught, then i might be into it more
    Cheers guys
    clixanup is offline Has Left
    Jan 2004
    Quote Originally Posted by SL/ENut
    A 350 Holley is overkill on Holden 6s unless you've got (at least) a decent cam.
    On an otherwise stock engine, a better (and cheaper) option would be a 2 barrel Strommy off a red 4.2 from around the same era.
    Some other options:
    1. A HEI dizzy off a VC/VH.
    2. If its auto - convert it to manual with a 5 speed box from a Toyota Supra. A short-ish diff ratio will help a lot too (say between 3.45:1 and 3.7:1). 5th on the Supra box is overdrive, so you shouldn't have any issues with fuel economy on the highway. If you buy most of the parts from a wrecker, you should be able to do this fairly cheaply - provided you do most of the work yourself.
    3. If it has aircon, ditch it because it probably doesn't work anyway and only puts extra load on the engine.
    Bax
    Nothing
    Jan 2004
    QLD
    Would you seriously ditch aircon for a few extra kw?? I'd rather be comfortable.
    Jan 2004
    Quote Originally Posted by bextor84
    Fair enough. Its a VB though, so it probably doesn't work anyway. IMO Commodore aircon was useless up to VL.
    VL aircon is good 'cause its Nippon Denso which is one of the (if not the) best.
    VB
    Jan 2005
    Central Coast NSW
    how do u go about fitting a 2 barrel strommie of a 253 onto a red 202. Adapter plate or different manifold? and also what about linkages?
    CAUTION:Any attempt to overtake will result in a race
    Jan 2004
    Quote Originally Posted by bassfiend
    New manifold. These people should be able to help you with linkages too:
    http://www.redlineauto.com.au/
    VB
    Jan 2005
    Central Coast NSW
    as far as i know the only way to do this is to find an inlet manifold from a 186S motor, as this motor had the 2 barrel as std. And i don't think redline make a manifold to fit. Either that or i will make up an adapter plate for the 2 barrel holley manifold i have.
    Jan 2004
    The 186S manifold will make a post 1976 car unroadworthy.
    Redline make two-barrel manifolds for Holden Red 6s.
    VB
    Jan 2005
    Central Coast NSW
    the manifolds they make are only for a holley 2 barrel tho, if they do make one to suit to 186s carb i have never seen one or heard of it and it is no longer on the site. Unless it will fit the holley 2 brl manifold?????
  15. #15
    Jan 2004
    Ring 'em up and ask.
    And the 186S carb isn't the one you need. You need the carb from a post 1976 253 V8 (either Kingswood or Commodore will do.)
    The reason being that post '76 have emissions controls.
  16. #16
    rattattack1313 Guest
    a 179 (or 173) in a commy?? wow..... rip it out, give it to someone you dont like, and throw a 3.3 liter in her with a yellla terra head..... or even keep the 173 head and slip that onto the 3.3..when doing the timing, advance it as much as it will let you.... see how that goes......and 149 heads are awesome on red, blue and black strait 6's......
  17. #17
    Jan 2004
    Quote Originally Posted by rattattack1313
    But the Blue & Black motors have a different water jacket design to Red motors, so this makes Red and Blue/Black heads non-interchangeable doesn't it?
    Re: the 149 head: does it increase the compression?
  18. #18
    VB
    Jan 2005
    Central Coast NSW
    you have to drill a few holes to fit the blue head to the red motor
  19. #19
    Wink compression...
    Quote Originally Posted by clixanup
    it surely does, matey..... the cavities the valve seats live in ( on the 149 head) are smaller than the other heads...therefore, less space..more compression.......didnt know there was a difference between the colored motors.... i always had red motors, and have always put on heads from 149;s, 173's. etc onto 202's....until the last engine exchange on the HJ,when i put a souped up black 3.3 vb commo motor into her....bloody thing flew then , i can tell you....
    oh yea...the harmonic balancer on strait sixes is rarely in line, like it should be...so when you tune it, if you use a timing light, you probly wont get the right settings..i always did it with the light, then advanced it about 6-8 deg....... the mother flew then!!!!!
  1. T700 weak?
    By Shifty1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2008, 12:19 AM
  2. piss weak fordv8z
    By commisme in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-12-2006, 04:27 PM
  3. How weak is weak
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 10:56 PM
  4. Weak brakes!!
    By keza87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 10:01 PM
  5. Weak Headlights
    By craige1982 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2006, 11:29 PM
