Results 1 to 23 of 23
Thread: A Few VH Questions
    253 VH, 400rwhp 12at 323
    Aug 2007
    Under a car, NSW
    Default A Few VH Questions
    Hey guys, I've done a bit of a search, and I was wondering if you guys could help me. A couple of months ago I picked up a VH, it's a pretty clean car with 253, lpg and a supra 5 speed. It's a great car, but I just have a few questions:
    - Trims: it has the rubber trims with the chrome strips and the one on the drivers door came off. I bought the proper double sided tape stuff for car body trims but it only held it on for a couple of weeks, I assume because they are much heavier than normal plastic trims. What is the best way to stick the trims on? Also, are these trims still available to buy anywhere?
    - Taillights: Is there anywhere that VH taillights can still be bought new? I can't find any aftermarket, and although I haven't rung them I assume Holden don't still stock them?
    - Rust repairs: The car is very good, but has the usual bit of rust around the windscreens. Does anyone sell rust repair sections for these areas?
    - Paint Colour: It is a pale blue colour, I believe it is the factory colour though the car has been resprayed at some point. Could anyone give me any tips as to what the colour might be?
    If anyone can help me with these questions that would be great. I'm just looking to tidy up the car and continue to drive it for now, it drives great for what it is. When I finish my current project (turbocharged rotary) I will build a blown v8 to drop in it and overhaul it a bit more. Any help you guys can give me would be great.
    Thanks in advance.
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    tail lights - I'm pretty sure most car parts stores should be able to get them. repco can order TYC ones.
    ECOTEC KICKED IN yO!!!!!!
    Aug 2007
    Under a car, NSW
    Thanks mate. I've contacted quite a few online parts stores who told me they're no longer available, but that's a good thought, I'll try and get to Repco this weekend. Do you think they may have rust repair sections too? Perhaps Rare Spares would be a better bet for that.
    Anyone know the best method for sticking the trim back on? The car looks crappy with one trim missing.
    VP Executive R-spec
    Jan 2005
    If it's pale blue if may have been a South Australian highway car but I don't know if they ever used them with 253s, you could probably get VH's in another pale blue also, you can use some bonding stuff to get the trim on but you mjight wish you didn't if you have to get it off again
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by metalhead View Post
    Thanks in advance.
    Can't remember the name, but there's some black gear which u should use for the strips. We got some out in the shed but can't remember the name, it comes in a dual tube sort of thing, one tube has a black gear in it, the other has the gear which once mixed with the black stuff it sets off.
    As for the window rust repairs, the front piece is called the cowl panel. Holden don't make them anymore, but repro ones u can get from RareSpares for about $180. We're wrecking a VK and VH at the moment, and the cowl panel is 100% rust free on one, and minor surface rust on the other, I can chop it out if u want it, as well as the rear window section....PM me if ur interested and we'll work out a price. I'll only chop around the cowl panel (don't have time to make it all neat coz we've got 2 wrecks to dump on the weekend, and need to strip them within the next few days), so you'd have to drill out the spot welds and stuff b4 i could use it. I don't want heaps for it, so let me know ASAP. I might be able to post it too.
    I think the cop cars were a pale blue, but not sure of the colour. There's also Pacific Blue, but that isn't really a pale blue, and it's mostly on Vacationers I think.
    Aug 2007
    Under a car, NSW
    Thanks guys, I'll see if I can hunt down some of the black stuf described, a product name would be great if you think of it or see it, but that probably should be enough description to find it. PM sent regarding repair sections, I'm in Sydney though so it will depend if it's worthwhile.
    Also, I pulled up a corner of the carpet last night, and the box section on the passenger side is white. Does this mean the car was originally white? I knew the car had been resprayed at some point, but I thought under the bonnet was the original paint (it looks like it's seen 26 years of work!), and it's the same colour as the bodywork so I had thought the colour was the original.
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    Quote Originally Posted by VHPirie View Post
    Is it that Sikaflex stuff or however it's spelt? I think thats black...
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    DANNY8's Avatar
    Apr 2004
    Just went and checked and the stuff I got is called 3M Automix, 8115 Adhesive. It says on it that it's NASCAR officially licensed. I guess just go to a hardware shop and ask them bout it. We used it to chuck the side strip back on PEAKN6, and it hasn't come off yet. Also used it to put around the top of my pedal box around the clutch cable hole. The foam was crusty (the small bit which is visible in the engine bay), so smeared this gear around it and once dried it looked all shiny and nice
    I got mine from work, I empty bins and clean up their mess (crash repairers), and I found a tube of it half full in the rubbish....we needed sumfin for the side strip so brought it home, works a treat!
    VX Calais V6 Supercharged
    Sep 2007
    the colour is called manet blue
    edit: i had a vh which was manet blue and no it was never a police car.
    Nos_VQ is offline Hot Rod Metal Fabricator
    VH SLE, VH wagon, 54 Plymouth
    Feb 2005
    Sikaflex®-529 is a multifunctional one-part polyurethane hybrid sealant for car body assemblies.
    SSS makes reproduction vh tail lights.
    Search ebay for rust repair panels. They come up from time to time.
    DANNY8's Avatar
    Apr 2004
    Yeah....the cowl panel I chopped out for u will be on eBay soon if u don't answer ur PM's
    Just let me know if u don't want it coz that's kool....it's just I need it gone ASAP.
    Aug 2007
    Under a car, NSW
    Haven't been on here for a few weeks, PM sent to VHPirie.
    Thanks for the information on the paint colour and what to use to stick on the side strip guys, I've been flat out with work and moving house so haven't had a chance to follow up on it.
    mjh
    mjh is offline Fully ****? Fully Sick!
    vh sedan sl/e
    Oct 2007
    central coast
    i happen to have a vh too n i was just wondering where i could find the bit of chrome above the driver side head light... i have searched on ebay n rare spares but no luck
    plz help i want a complete car
    MjH
    mjh
    vh sedan sl/e
    Oct 2007
    central coast
    Default plz help
    i have a vh n its missing one bit of chrome n a bumper cap! i have searched on ebay n rare spares but no luck yet
    any ideas on where i could get them on the central coast?
    MjH
  15. #15
    Feb 2005
    We have those parts at work and we can send australia wide. Pm me if your interested.
    vh 1982
    Nov 2008
    Jakarta Indonesia
    Smile VH engine specifications
    Hi Guys,
    I really need some help fast. I live in Jakarta Indonesia, and I have 2 Holdens that I bought here. An LJ Torana and a VH Commodore. I just broke a piston ring in the VH (4 cylinder blue motor) and I want to rebuild the engine while it is being pulled apart by the Indonesian butchers.
    I can get the parts here no problem, but I need the specs, like torgue settings etc. Is there an online workshop manual that anyone knows of. I cant seem to find one on the net.
    I don't want to have to buy one online coz I will be going back to Oz for a trip in February and will get a second hand one then.
    I would really appreciate any help I can get.
  17. #17
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
  18. #18
    jakbob's Avatar
    jakbob is offline Lighten up.
    VX SS, VC L, VK Vacationer
    Dec 2008
    Quote Originally Posted by ari666 View Post
    think you are better off going to NZ cos' i dont think we ever got the 4cylinder commo's
    We did in the vc for sure and I think the vh.
    Four commodores and counting.
  19. #19
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by jakbob View Post
    yup 4cyl 'Starfire' powered VC's & VH's were released in Australia. I remember working on a few of them
    I'm fairly sure the gregorys/haynes workshop manuals include the 4cyl.
  20. #20
    ari666's Avatar
    1966 impala
    Mar 2009
  21. #21
    DANNY8's Avatar
    Apr 2004
    I've got a Gregorys VC manual in pdf but that doesn't include the 4 banger....also got the Max Ellery VB-VK manual in pdf but that doesn't have it either.
  22. #22
    VH SS
    May 2009
    Toowoomba, Qld
    well at a guess I'd imagine most torque settings would be similar to the 6 cyl as they were essentially a cut down Holden 6..... don't hold me to that though
  23. #23
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by Darren_L View Post
    id guess you were right as 6/8 are pretty much the same too.
  1. CPI lpg questions
    By Outlaw Torn in forum General
    Last Post: 18-09-2006, 09:09 AM
  2. Two Questions
    By jamo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2006, 10:21 PM
  3. A Few Questions
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 10:29 PM
  4. 2 questions
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2005, 03:54 PM
  5. VY 914 Questions
    By mungx2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-09-2005, 06:24 PM
