Results 1 to 7 of 7
Thread: gearbox questions
    VH and VT S2 Berlina ecotec
    Aug 2007
    Brisbane-northern suburbs
    Default gearbox questions
    hey guys and galls just a quick question, im under the impression that the v8 vh's had a m41 turbo-hydromatic auto does this fit onto a 202? cuz im up for a new box but i have plans in the future for a v8. also i think the vl's had a m40 trimatic like the vh's 202 (tho i assume stronger) so if i just get my current box rebuilt (they said they can do it to handle a v8) will that just bolt up to a vl v8?
    also now i could be wrong but if i use a vl block, vn efi heads will bolt onto it? cuz im planning on running efi.
    any comments or suggestions would be great
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by VH commodore View Post
    Short answer: No.
    The bell housing and bolt pattern of the turbo box will be very different to that required for a holden 6. IIRC the old 202 used the old "aussie" bolt pattern with the m20 & Trimatic autos. This was different to that used on the V8's (m21 pattern) and the input shafts were different.
    I don't think it will bolt up to the VL block - it also depends on weather it is a trimatic or turbo bolt pattern.
    Further more, the VN heads will bolt onto any Holden 308/4 block. You will need to change your inlet/exhaust manifolds and camshaft as the ports and valves are arranged differently. It is a very common project and all the parts are readily available.
    Reaper
    Aug 2007
    ok thanks so there is no box that will fit onto both a 202 and a 308? its just my current trimatic is on its way out and i have plans prob next year to put a v8 in it, thinking i could get that part done now saves me doing it twice.
    Reaper's Avatar
    Aug 2004
    Uhhh - ok. Well the V8 traumatic will have a different bell housing, input shaft, flex plate, starter motor (I think), torque converter for a start. I'd suspect the internals will be significantly different too but you would have to talk to an auto guy to give you an exact run down.
    Reaper
    Aug 2007
    yer ok i'll have a talk to the guys at the transmission shop, but it seems like its not going to work
    thanks for your help
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    i had 6 cylinder trimatic in my 308 commi when i replaced my v8 trimatic ive allso used the 6 cylinder trimatic torque converter in v8 as a high stall just the bearing in there didnt like it for long
    VC,VK, VN
    Feb 2007
    castlemaine rod shop will supply you an adapter to fit a T700 onto a 202, really just about anything onto anything lol.
    check em out.
    The Castlemaine Rod Shop Engine & Transmission Adaptors
    bugger swapping heads and crap, just grab an VR 304 you can get the lot for around $1800 and drop that in, they'll probably throw the tank in as well.
  1. Gearbox Questions?
    By VBSLE in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-05-2009, 12:46 PM
  2. What gearbox do i have ????
    By Mr Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2007, 01:18 PM
  3. vs eco gearbox
    By lukas pukas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2007, 01:43 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. a few questions about VS series 2 (suspension and gearbox issues)
    By heatersarecool in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2005, 11:57 PM
