Results 1 to 11 of 11
Thread: New Engine priming oil
    Sep 2007
    Default New Engine priming oil
    Just a question on how to prime the oil pump on a new 202. I gave it a quick start tonight but it seems as though there is no oil pressure and no oil going into my filter. It starts for about 30 secs due to not being tuned yet but I was wondering if there was a way to prime the oil system?
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6
    Hilux 4.0 V6 SC 320kw
    Jul 2006
    Mackay Qld Australia
    I once knew a mechanic who always put quite a bit of vaseline into the pump itself so it would suck properly and prime the system first go.
    Being petroleum based it disolves into the oil right away and causes no dramas at all, I would prolly change the oil the next day just to be sure.
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
    Sep 2007
    dreamcatchu's Avatar
    dreamcatchu is offline sick puppy
    VC Commodore
    Sep 2004
    Bundaberg qld
    all i did was pre fill my filter and pump with oil, but the vaseline trick does work but some pump manufacturers will void there waranty if they find out
    Sep 2007
    VT Berlina & mazda 2 DE
    Jul 2006
    You can half fill the filter and get it on quick without spilling much- I do it on the VT resonably successfully.
    I've always been taught that providing you have pre lubed everything before assembly, remove the leads so it wont fire, but crank her over for a minute or two, bringing pressure into the pump. Then start.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Thats the way I do it. But I have the plugs out too so it winds over fairly quickly. Hook an oil gauge up to it, turn it over until the pressure gets up over 30psi then it's good to go. If you haven't got a guage, turn it over until the oil light goes out.
    Visit my Facebook page
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i use both the vaseline in the pump and prefill the filter, fill it, let it sit for 5mins and fill gain, do that untill it won't take any more and the oil level is just under the threaded hole, then cover with vaseline to stop oil coming out whe nputting filter on, it helps, doesn't stop all oil but it will stop some. with the 202, have the rocker cover off and use an oil can to squirt some oil over the rockers etc before first startup. i know some guys that soak the lifters in engine oil before putting into engine also.
    cranking without plugs is also the best idea to get the oil presure up quick
    Body by Holden, Soul by Brock
    the Legend will live forever
    Sep 2007
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    Sep 2007
    Would like to thank all for the info. Started it tonight finally. I ended up using an oil can to fill up the pump and also fill the filter. Worked a charm so once again thanks.
  1. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  2. Priming Fuel system
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-04-2007, 11:47 PM
  3. fuel pump not priming
    By Snotty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2006, 09:11 PM
  4. fuel pump priming problem
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 11:57 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
