how you all doin , im startn my first 6cyl project and am wonderin if i can bolt a red injection ram on a black motor (are red and black heads the same) iv been given a rebuilt garret to4 and i wanna run the turbo into the injection manifold (whats the best way of doin this can any one help
by red motor im guessing you mean a vk efi motor (which is a black motor with a red intake manifold and rocker cover)
if you mean a red motor (out of a vb or older) then no the heads are not the same
if your going the turbo route you will need to rebuild the bottom end, shot peened rods, hq racing pistons, full balanced and id get the block or ringed also
you will need an after market harmonic balancer such as a romac or stock ones will just fall apart, you will also need an after marker computer such as a wolf, haltech ect ect
oh and btw big horse power 202's dont last long as conrods end up on the ground![]()
thanks Dose Pipe , youv answerd all my questions in one
