Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: red gear into blue motor
    The Darkness's Avatar
    The Darkness is offline Junk Yard Dog
    Charged VT V6 A4
    Nov 2006
    Ipswich
    Default red gear into blue motor
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Yeah the pistons are the same, aslong as both motors are 202's or 173's etc etc.
    I was watching a set of NOS GM pistons on there and 2night they finished....the whole set sold for about $21!
    I got a set of new 186 flat tops (being 186 they were for a red motor) for my blue 173, just got it bored out 130thou to fit them in. The bore size is now the same as a virgin 202. So now it isn't a 2.85L 173, but a 3.0L 186.
    Charged VT V6 A4
    Nov 2006
    Ipswich
    lol. im also watching some crow cams heavy duty valve sprinsgs. planning on puttin a small turbo setup. just a little bit of extra power so im modding my 202 now
    DANNY8's Avatar
    Apr 2004
    How much are the valve springs goin for? Can't seem to find any for a holden 6 listed on ebay. Don't worry I don't wanna buy them from under u or anything lol, just curious. I bought new ones (Crow heavy duty) which cost me $75.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by VHPirie View Post
    BORED 130 THOU" !!!!!!!!
    Selling FG G6E Turbo and buying a N/A Supra
    Charged VT V6 A4
    Nov 2006
    Ipswich
    these are $60 new.
    VP 5L Calais
    Mar 2007
    S.A
    Quote Originally Posted by AirStrike View Post
    i thought the same thing.
    DANNY8's Avatar
    Apr 2004
    haha its sounds a lot, but it was a 173 to start with. How it is now is the same as a virgin 202 block. A 186 has the same bore size as a 202, only it has smaller stroke.
    A mate at work thought I was dribbling sh*t coz he said ya can't get pistons bigger then 60thou over. But I bored it out to the standard bore size of the 186, so std 186 pistons would fit. 202 pistons won't tho coz the pistons will hit the head. I can put 202 pistons in if I put a 202 crank in as well, which will then take it up to 202 cubes (of course), but that will just be like a standard 202.
    The 173 and 202 blocks are identical, except the bore size is smaller in the 173, therefor if someone is after a virgin 202 block, they can just get a 173 block (even if it's bored out 60 thou, coz it's still under 202 spec) and still bore it out to the std 202 bore size.
    173 + 130thou = 186 (or 202 if I use 202 pistons and crank). You can also chuck a 202 crank and pistons into a 186 red motor to bring it up to a 202.
    Put simply, I can still go another 60 thou like the normal 202's.
    Sry for being so repititive, I'm just crap at explaining technical stuff haha.
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    what vhpirie has done is quite safe (id hope so as i sold him the pistons :P) he still has another 80thou to go before it starts getting sketchy
    VP 5L Calais
    Mar 2007
    S.A
    it amazes me that the 173's have adequate cooling around the bores if the walls are that thick.
    DANNY8's Avatar
    Apr 2004
    I think 130thou is about 3.2mm (thx to Google )....so it isn't really heaps....but I guess in a motor where everything is exact and important, something small is actually big.
    I haven't started the motor yet so dunno wat she's gonna do...hopefully within a fortnight if I get off me bum.
    vz wagon
    Aug 2006
    Wild west of Melb
    Quote Originally Posted by Dose Pipe View Post
    Id be having the block x-rayed befor i was boring a block any more than this even now it would be at its limit.
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by Clutchy View Post
    technically it aint at its limit coz after boring the 173 block out 130 thou it is now the same as a std 202 block.
    Sep 2005
    I love how all the experts who dont even own an old holden 6 are comenting....
  15. #15
    1999 Landrover disco series 1, 2006 Street Bob
    Jul 2006
    gold coast qld
    it sounds right to me. same go with tha v8s i think. 253, 308 and 350's are the same block size
  16. #16
    VP 5L Calais
    Mar 2007
    S.A
    yeah i'm not arguing it, i just thought that because the walls between the bores and water jackets would be so thick on a 173, how do they not overheat.
  17. #17
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The red 202 pistons will fit a blue block but the red motor conrods are weaker.Blue and black motors have stronger conrods with thicker bolts so they can handle more revs.
  18. #18
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by V85000i
    I would of thought having thicker walls would be better. More thickness which means more metal to take more heat. I guess that would work hey?
    Quote Originally Posted by Tree cutter
    Blue/black rods are starfire rods hey? Which seem to sell pretty good. It seems on eBay if u have 2 auctions, one for a set of rods out of a blue 202, and a set of starfire rods, the starfire ones get a lot more attention coz of the name.
    In my 173, I used the standard 173 crank and rods (got it all balanced up as well), then the red 186 flat tops. So I'm still using the blue bottom end except the pistons. Hope it goes ok.
  19. #19
    VP 5L Calais
    Mar 2007
    S.A
    yeah that makes sense, i suppose it doesn't matter either way, if the walls were thinner the heat would be dissapating into the water and being taken away by the water flow to the radiator.
  20. #20
    Jul 2006
    gold coast qld
    Quote Originally Posted by Tree cutter View Post
    is there any difference at all between tha black motor and tha blue motor. i know tha black motor is a later model motor. in tha vk's i think
  21. #21
    DANNY8's Avatar
    Apr 2004
    yeah the VK had the black motors. I don't think there's much difference at all between the blue and black motors. The black had a slightly better flowing head (apparently), and of course the EST or EFI system. But other then that I don't think there's anything different except the colour.
  22. #22
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    I may not own one now, doesn't mean I didn't in the past. Had a worked 202 in a LJ. I just feel that 130 thou" is a lot of meat to take out.
  23. #23
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by quick308 View Post
    350 is a totally different engine.
  24. #24
    Jul 2006
    gold coast qld
    is it oh well there ya go. i was not totaly sure thats jus what iv been told. so tha 350 has a larger block then
  25. #25
    VP 5L Calais
    Mar 2007
    S.A
    the 350 is a chev motor, 253 308 are holden motors
LinkBacks (?)
  1. 20-11-2007, 12:20 AM
  1. Doing up a 173 blue motor??
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-07-2010, 08:14 PM
  2. EFI gear on a blue 202
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2007, 01:38 AM
  3. 2.8L blue motor, how much??
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2006, 07:15 PM
  4. 2.8L blue motor?
    Last Post: 18-06-2006, 03:16 PM
  5. Blue Gear Selector
    By AirStrike in forum General
    Last Post: 23-11-2004, 06:41 PM
