Righto I have had a bit of a search on the forums and so far haven't been able to find what i'm looking for.
Hopefully someone can help.
I am trying to get a parts diagram or a photo of the vapour lines attached to the fuel filler neck, as the ones on my VH have perished and litterally fallen off. My Gregorys manual or the pic I got from Holden do not have a clear enough picture unfortunately.
So any help is appreciated.
Had to go through the same thing about two months ago, the pic is not that good at all.
from memory, if you look at the tank as if you are filling up, there are 2 intakes on the fuel tank which have fuel lines that are connected to a semi circle connector on the fuel filler neck (underneath the connector), on top of the semi circle connector you then have 2 lines heading up to the top of the fuel neck but they connect to a plastic T piece which then gets connected to another connection at the top near the fuel return hose, that covers the tank but if you look underneath the cover to the very top you have a sort of L piece pipe coming out of the fuel filler tube this is connected to the return line from the charcoal cannister at the front of the car.
Hope this helps and you can understand.
cheers
Thanks for that vhsle83...
I am slowly getting it sorted out.. I am pretty sure that the 1 way valve thingo is the one that goes to the charcoal canister. Yeah so should just leave the pipes from the T-peice going to the seperator block (plastic thingy cable tied to the filler neck).
Cheers for the help
Good work mag
The set up in the pic looks a little different to mine but it should all work out...
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
