Results 1 to 16 of 16
Thread: engine conversions?
    vk commodore
    Apr 2006
    Default engine conversions?
    does anyone no what the largest capacity engine is that can legally go into a vb-vk? has anyone ever heard of a 350 oldsmobile or pontiac in a commodore, instead of a chev? what are some of the strangest conversion that you have seen?
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    One of the dirt circuit racers here put a Ford inline6 OHC thing into an oldskool Commy. That was about a year ago, and obviously wouldn't of been engineered coz they don't need to coz they're track use only.
    253 VH, 400rwhp 12at 323
    Aug 2007
    Under a car, NSW
    vk commodore
    Apr 2006
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    seen alot of chevs but no oldsmobile and stuff... mainly becasue u cant get it on the road with those engine
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i thought the 350's in them were made by chev anyway?
    We got rep back, yaaay!
    vk commodore
    Apr 2006
    why would u not be able to get them on the road? they are the same capacity as a chev, so there is no problem there. chev, buick, oldsmobile and pontiac all made their own engines. all made a 350, all are completely different. the pontiac and olds have the starter on the left hand side, unlike the chev. iv read that a bloke has had a 403 olds in a vb. i think this was in vic n some years ago. perhaps no longer allowed.
    SL/ENUT's Avatar
    SL/ENUT is online now The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Cause the VB-VKs never ever had the option for a 350, the emissions aren't correct, you need to get it engineered. Most automotive engineers won't pass a chev, oldsmobile, hemi in a VB-VK.
    Now the strangest engine conversion i have heard was a 289 Windsor in a VB.
    vk commodore
    Apr 2006
    what about if you run it on gas research. then there should not be a problem?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Gas can be fine.
    But do you know that you need to get engine mounts made? also other parts to make it fit in correctly?. To do what you want to do, you need a lot of coin.
    With that coin, you could have a very tough Holden base 5 litre, either carby fed or EFI. Stock stroke or a stroker
    Mar 2006
    Quote Originally Posted by vkhawkey View Post
    im talking a decade or so back when the rage was to shovel a 350 chev in a vb-vk and when the laws were abit more relaxed...
    and why would u drop in a an oldsmobile when u coulda had worked up chev
    and getting it threw emissions today would be craptastic...
    i mean u could go buy an gen 3 or stroke out a 5 litre for the money it would cost to get the 350 in there
    DANNY8's Avatar
    Apr 2004
    A local here has a VB/VC wagon with a hiace diesel motor and 5 spd trans in it. The gears are all backwards. That's all been engineered....he's even customised the front struts to fit chunky tyres on it. Did it all himself, he said it took him 2 weeks, but lots of planning b4 hand.
    vk commodore
    Apr 2006
    all the 350s mounting position is exactly the same. so if som1 makes a kit for a chev into a vb-vk, then it can also be used with an olds. i cant see it costing a great deal. how hard can it be to fabricate some mounts that will pass an engineers report anyway? i have seen 403 olds for sale on ebay 4 $500, and not get a bid. i really do not think it would be an xpensive project. a problem mite be actually finding an engine
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Last time i looked, the whole conversion kit for a 350 Chev into a VB-VK was about $4000. Then you have to get it engineered, another fair bit of $ gone.
    To fabricate your own mounts, you need to be bloody good!
  15. #15
    VB SL/E
    Jan 2008
    wa
    350 oldsmobile isnt the same as chev ( in wa i was told you are aloud 50 cub more than what the car came out with dont no if its the same over there)
  16. #16
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    IN NSW the formula for calculating maximum allowable engine capacity is the original tare mass of the vehicle in kilograms multiplied by .294.
    So a Vb-VL V8 commodore would be 1275kg(from memory) x 0.294 = 374.85 cu in.
    If you go to the RTA webside and do a search for VSI 06 you will find the relevent document.
    Better still use this link
    http://www.rta.nsw.gov.au/registrati...s_nov_2007.pdf
    Last edited by tigervh; 14-02-2008 at 12:03 PM. Reason: buggered up the quote tags
  1. R31 R32 R33 R34 R35 conversions?
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-06-2009, 06:18 PM
  2. 5 speed conversions? help please!
    By scottcalais369852147 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-01-2007, 04:01 PM
  3. Some Useful Metric Conversions =D
    By s0sage in forum Jokes/Humour
    Last Post: 23-11-2005, 07:01 PM
  4. engine conversions
    By quick202 in forum General Discussion
    Last Post: 27-09-2005, 11:30 PM
