Results 1 to 3 of 3
Thread: 202 efi engine rattle
    vk commodore
    Apr 2006
    Default 202 efi engine rattle
    my 202 has a top end rattle. the bloke i got it from said the head had been done up. i checked the cam followers and they looked brand new. i then changed the pushrods and rocker arms, from an engine that didnt rattle. the rattle was still there tho. what could the problem be? worn cam? thanks
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    You probably need to set the lifter preload. Get number one cylinder at TDC then undo the two rocker pedestal bolts and check the gap between the bottom of the pedestal and the head with feeler guages. The gap should be 20 to 40 thou. You will need to either put washers under the pedestal to make the gap smaller or grind the bottom off the pedestal to make the gap larger. You push down on the pedestal with your hand when checking the gap. You need to do one cylinder at a time winding the engine over until the cylinder you are working on is at TDC then tighten the bolts up when you get the clearance right.
    vk commodore
    Apr 2006
    thanks, did it today, fixed the problem
  1. engine rattle
    By Greekos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2007, 11:20 PM
  2. VZ engine rattle
    By blu61 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-09-2006, 08:38 PM
  3. engine rattle really bad
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-04-2006, 10:33 AM
  4. Engine Rattle
    By VPCalais38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2005, 05:40 AM
  5. ls1 engine rattle
    By pizzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2005, 11:58 AM
