Results 1 to 5 of 5
Thread: Vacuum advance outlet on Varijet II?
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Default Vacuum advance outlet on Varijet II?
    hey everyone, ive recently swapped my black motor from E.S.T ignition to the HEI Electronic dizzy off a blue motor. My car has been in the mechanics and i've been told that i'll need to get the carby off a blue motor aswell, cause theres no outlet to run the vacuum advance off of.
    my question is there a way i can hook up my vacuum advance from the Varijet II carby on my black motor? or do i actually have to get a carby from a blue motor for it?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    if i remember vkberlina site's has the diagrams for the vac system if you go there and look use one similar to the efi. I cant really remember how it was on my vh but similar to the efi
    Feb 2006
    Radelaide
    its only 1 hose i need to know about, the vacuum advance from the distributor? is there a spot where i can connect that to and it will work or do i need the blue motor carby too???
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    All you need to do is hook it to the inlet manifold somewhere. It runs to a direct vacuum feed off a carby. Usually towards the bottom there is a fitting that runs into the venturi of the carby. So any vacuum line off the manifold will work.
    Visit my Facebook page
    VN/VT
    Sep 2005
    SA
    what he said ^^ there is usualy spare inlets to feed from well mine has.
  1. keep hearing about replacing Varijet with Ford Carby
    By AitchEBoy in forum General Discussion
    Last Post: 30-11-2007, 09:40 PM
  2. Vacuum hoses on Varijet + 202 Blue Motor, VH Commodore
    By Dr_Mutley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2006, 02:00 PM
  3. WTB: Varijet 2 carby for blue motor
    By Nos_VQ in forum Swap / Wanted to Buy / Trade
    Last Post: 02-05-2006, 05:52 PM
  4. Varijet and LPG
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2005, 02:37 PM
  5. 308 vacum advance
    By gammin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-10-2005, 10:37 AM
