Results 1 to 3 of 3
Thread: Fan trouble in VK
    vk sl
    Nov 2007
    Default Fan trouble in VK
    I own an 84 vk with 94000k's on the clock and i just got my air cond dun accept my fan only works on number 4
    it used to run on 2 and 3 but not any more
    please help
    Brucefromruse is offline CRAVEN MOORHEAD
    VS executive s2
    Oct 2007
    Campbelltown nsw
    well i have a VS and from what ive read it seems like something to do with the resistor under the wiper region....however check out Kopper69 blogs and stuff he seems switched on.
    commsirac is offline Banned
    vx
    Aug 2007
    Assume you are talking about the blower fan inside the cabin and not the fan on the condensor.
    As stated ^, typically if high speed is working an the others are not, the problem could be that the resistors have burnt out or the connections to these are suspect, what about no.1 speed? It could also be your switch which is causing the problem. Top speed is when the resistor block is bypassed and the fan gets full voltage, typically switched by a relay.
    You will find the resistor block somwhere close to the actual squirrel cage on the aircon box. It should be accessible to visibly inspect the coils.
    Otherwise, Depending on how easy it is to get to the switch or the resistor pack, test the voltages to see which is at fault, if you need some guidance here send me a pm.
  1. T Bar Trouble
    By webby 6000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2007, 11:00 PM
  2. In Trouble
    By DOG in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-10-2006, 10:11 PM
  3. Having trouble
    By aw006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2006, 07:21 PM
  4. Vn Trouble
    By Stewart1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2005, 08:21 PM
  5. trouble
    By bigazza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-08-2005, 04:01 PM
