my brke lights have screwed up. it blew the fuse a couple times. replaced and was ok but soon blew again. but now they wont work at all. tried different amperages of fuses none of which blow now, earth is fine, new bulbs nothing is working. need it fixed quick cause mums car just got canaried and spare car suddenly screws up![]()
Did you clean every single earth point? That can make a differences. Also the bit that holds the brake lights, replace them and see what happens.
ok will try that. will stop in at teh wreckers and get a few.
fixed. connections behind the brake pedal assembly wern't good.
