Hi all i was wondering if someone could tell how strong a VL V8 diff is i have a 10 bolt at the moment but it has 2.6 ratio mini spool which i cant get a roadworthy with i was thinking a vl diff because i am led to beleive parts are easy to get for them ie: lsd parts,Also if were to buy a drum brake diff how hard is to convert to disc brake as i have disc brake now?
If anyone else has any suggestions they would be greatly appreciated, Thanks.
the VL V8 diff are strong, a tad more stronger than a 10 Bolt. Only difference is that a Vl V8 diff is a few mm longer, 2 mm each side i think.
Also the VL V8 diff are disk brake factory. And they are 3.08:1 ratio.
thanks alot for your help theres just one thing though the diff i am looking at im told was out of a vl v8 wagon it has drum brakes an is a 3.45 ratio was there a differance when it is out of a wagon ?
Shocky mounts are different from a wagon diff to a sedan diff. SLENUT has pics coz he posted them in one of my threads.![]()
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
Well, if the VL wagon is factory V8, it would be disk brake standard and 3.08:1 ratio. Sounds like its had a swap in its life.
Anyway wagons have this for a shock mounting point.
This the one currently in my VB, with sedan mounting points welded onto it.
Can you tell the difference?
these are the photos of the diff do you have any suggestions what it might be if its not a vl v8 diff thanks alot
I reckon its a stock standard drum brake VL wagon diff. They have 3.45:1 ratio.
ok cool so you think its just a 6 cyl one ? thats a shame that pretty much puts me back to the drawing board oh well thats just the way things go i suppose thanks alot for all your help i will find one in my price range eventually if there is any other suggestions of what diff i could use that would be greatly apreciated thanks again sl/enut for all your help
