just so i know what to expect, can i get some more details on what else has to be modified when changing the Varajet to weber 34ADM. I have the weber and getting an adaptor plate from Redline, although i am going to have to get longer bolts as the plate they have is for another model weber but matches up ok apart from having a thicker base which requires the longer bolts. What do i have to do with the auto choke and throttle cable etc? do these have to be modified/replaced, or can they be hooked up again. Any detailed info or step by step directions appreciated.cheers.
