Results 1 to 7 of 7
Thread: some vk advice.....
    jessedevery is offline JSD334
    VT Berlina S1
    Jan 2005
    Default some vk advice.....
    well iv decided to boot the VT off to the missus and finally go to an older model, had a vn, vr, vt, and just keep gettin disappointed. The VT is such a sack compared to the VR.....so im thinkin bout tryin a VK, but i have no experience with em...could some1 xpl the sl, sl/r or what ever they are...im guesin its like exec berlina etc, but which is which...any ground rules for gettin a VK......i hear stuff like red/blue/black motor...things to keep an eye out for...
    km etc etc
    im torn between gettin an absolute ****e box for like $100 or gettin a slightly better one...maybe 1500
    im keen to buy the **** box and learn how to spray.... i got the time...
    comments/suggestions would be appreciated
    cheers
    SL/ENUT's Avatar
    SL/ENUT is online now The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Models are:
    SL
    Executive
    Berlina
    Calais
    Also the odd Vacationer specials.
    The SL and Exec models are a base model, poverty packs. They have the basic black 202 EST motor, EFi 202 and 308/304 V8 optional, trimatic transmission or 4/5 speed manual. Some are optioned with rear disc brakes. Both have cloth seat facings. Air Con standard in Execs, optioned on SLs.
    Berlina is mid luxury spec. Has its own unique velour interior trim. Disc brake rear standard. Has more standard options than the SL/Exec VKs. Electric windows/central locking. Optional 308/304 V8
    Calais is a separate model in the VKs. Has EFi202 standard, 308/304 V8 optional. Auto only with the EFi202, Velour or leather trim. Electronic dash standard fitment. Unique exterior door moulds and colours.
    Now when getting a VK, check for rust in the doors, the area between the rear windscreen and boot, specially the boot lip, around front and rear windscreens. They do have there faults with bad earth. The EST 202 are crap, the main conversion is using a blue 202 Elec dizzy.
    Besides that, the VK aren't to bad. They have there following.
    HTH
    Dec 2007
    Check for shot springs and shocks. Also check the bushes for spongyness and collapsed ones.
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    the berlina didnt have standard rear disc brakes, and all electrics were options. (windows/locks/mirrors etc).
    look for one with under 200,000 km's and little to no rust
    vk sl
    Nov 2007
    hey, i bought my vk commodore from the first owner for 2100 and it only had 94000 on the clock, he was sum religious old guy that didnt like drving, it was completely stock and all ive changed is the head unit and speakers, its just a 202 but it goes alright.
    bad news is that even with low km's the engine still ages over time. such as tapets (lifters), rings, cam shaft and most brake boosters leak and rust sum of the eingine bay.
    after sum research i realised that holden werent havening a great deal of bizness at the time of its release so the eingine assembley was very average.
    but sum people have said that a rebuilt or recon engine are awsome quality so thats what i did and now its quiet, smooth, better on fuel.
    the best part about an older model car is that its **** easy to work on and u can fix it urself.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i always thought the VK1/2 are the best models, the ones with the letter box grill. the later model ones also have the borg warner 78 diffs which you can get plenty off good parts for from later models etc
    personally i've always like the SL's, nothing fancy, nice and light....go fast material. especially if you fit a 3800 buick engine or maybe an ecotec
    Body by Holden, Soul by Brock
    the Legend will live forever
    Dec 2007
    Quote Originally Posted by chrisvk View Post
    Yeah true, they are easy to work on but only after you familarise yourself on how motors work and what parts are what. I used to think exactly the same thing about older cars and thought modern cars were all complicated with their computers and injection. After going ahead and pulling apart late model Commodores and stuff, I realised quickly that there isn't really much difference between a 84 Commodore and a 2001 VY. The only difference is the management of the engine is controlled mostly by the ECU, so everything else is basically the same. I thought stuff it, it's a motor, I can fix it. I jumped in there and got what parts I needed and pulled everything apart and did it. Once you know how a motor and it's stuff works, you will find they are very much the same as older cars. They all have cams, whether overhead or pushrod, they all have valves, they all have either injectors or a carburettor, they all have a manifold and with or without a throttle body. Don't ever be scared of working on modern cars if you know how motors work.
  1. bit of advice
    By pitt88 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-04-2007, 05:47 PM
  2. Vx advice
    By VRV666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2006, 10:22 AM
  3. VG Ute need advice
    By sumna in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2005, 06:13 PM
  4. Need Advice
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 10:55 AM
  5. Some advice please.
    By trucker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 07:54 PM
