Results 1 to 9 of 9
Thread: vk efi distributor problem
    VK CALAIS
    Jun 2005
    South Adelaide
    Default vk efi distributor problem
    I need a new dizzy cap and dizzy, well i think its just the rotor button or something because its worn away, does this sound right? Its for a vk efi 6. i went to the wreakers to look for one but no luck. im guessing this means they arent cheap? how much are they worth? and the carby ones wouldnt be the same ha? anyone wrecking an efi 6?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Carby ones arnt the same. Have a look on ebay and you can pick up a EFI Dizzy for less then 50bux with postage. If its just the rotor button and cap these can be purchased brand new from repco, bursons etc.
    VK CALAIS
    Jun 2005
    South Adelaide
    are these disstributors only on black efi motors? i kind of need one urgently so dont have time for ebay etc. i was told i could get one off a blue motor? not sure if its the rotor button i just remember the raa guy tellin me the whole thing had to be removed to replace it so just figured id get the whole lot.
    cheers
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    To replace the rotor button, u just pull the cap off which is easilly done by flicking off the 2 clamps. Then u will see the rotor button in the middle which just pulls off. Both the dizzy cap and rotor button u should be able to buy new for under $30 for the pair.
    I'm not sure if black EFI dizzy's are identical to blue HEI dizzy's, but I know the blue HEI dizzy will drop straight in and work on the EFI motor. Just remember when doing the timing, the EFI motor's have to be set at 12 degrees btdc, where as the blue motors are 6 degrees. Most dizzy's have a sticker on them so thought I'd let u know so when u do the timing don't go by the 6 degree sticker on the blue dizzy.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Dec 2007
    The EST carb rotors are different to the EFI and earlier electronic distributors. I have been there before and the carb one wouldn't fit, so just go to the shop and buy a rotor to suit a EFI VK. About $15.
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    yeh the VK carby one (EST) wont fit, but the Blue and EFI dizzy's are identical in every way even the advance curve
    VK efi 3.3
    Nov 2011
    adelaide
    Smile
    hey wat about the red motor because mine has the same problem but there inst anything about the red model is it different
    vr v6
    Aug 2009
    Are you sure it is a red motor? .Your ride says it is a vk efi 3.3 ,so that would be a black motor(with red rocker cover).
  1. VN/VP V8 distributor
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-11-2007, 04:27 PM
  2. distributor
    By senator 416 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2006, 12:21 PM
  3. VN -> VR distributor
    By michael smith in forum Electrical Wiring / Questions
    Last Post: 25-01-2006, 10:38 AM
  4. VN V8 distributor into VS V8 ?
    By Michelson4301 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2005, 11:52 PM
  5. HEI distributor
    By shanevc308 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-10-2005, 05:18 PM
