What will be required to mount 19inch HSV Senator Signature rims on my VK?
I imagine I will have to roll the inner gaurds?
Will they fit under the car with "low" springs?
Thanks
Drew
We put my 18's under PEAKN6 which has lows in it and that scrubbed a bit. The gaurds aren't rolled tho, so once they are it shouldn't scrape. Also an adjustable pan hard rod would make it better as well. 19's shouldn't be to different, as normally the bigger the rim, the smaller the tyre so u should be able to put them on without to much hassle depending on how wide they are. My 18's on the back are 245, so getting a 235's would be a bit better.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
just roll ya guards and buy an udjustble panhard rod as old matey said..
i mean all i did when i fitted 19s to my old silver vl was roll the guards and i got away without scrubing and it was dumped on its nuts
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
and get pics![]()
just remember that the cops will prolly hassle ya for em, got a regency on the vh for the 18's in VHPirie's post
Originally Posted by davway
on the law side of things, if im not mistaken, it says you can legally fit rims 1"(one inch) larger than the largest factory fitted on all models. therefore since HSV fits 20" ers you can go up to 21" on any VE etc etc for each of the models.
so a VH can legally go to 17" since brock models came with 16"s max......i'm pretty sure.....
I've had BBS 20" s on my VH gp3 in QLD and have never been hasseled
As Mentioned in previous Threads Try These Mods.
Adjustable Strut Tops
Adjustable Panhard Rod
Roll Ya Guards.
Cheers.![]()
* RVN 355 *
