Results 1 to 7 of 7
Thread: T5 on a 253
    VNSS Atlas Grey
    Feb 2006
    Default T5 on a 253
    just want to ask if an T5 ( VN manual Gearbox) will bolt straight on to a 253?
    VN V6 0-60mph in 7.52
    Peter Brock
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    dont think so, you can get adapter kits, from CRS and Dellows.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VNSS Atlas Grey
    Feb 2006
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Not 100% mate, but i THINK they are, i remember reading, that you can get conversion kits.
    SL/ENUT's Avatar
    SL/ENUT is online now The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    The 253 are an aussie bolt pattern block, the T5 all have a turbo bolt pattern bellhousing so, yep you need an adapter plate from either CRS or Dellow, but remember, this will make the shifter sit back to far, you need to make some mods around the gearbox hole.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by SL/ENUT View Post
    There is also the option of plugging and re-drilling 2 holes at the back of the engine block. Dellow may do an alternate bell housing which also would be fine. I have never liked the adapter plates that fit between the block and existing bell housing though.
    Reaper
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Full new belhousing from CRS or Dellow, did look a a similar thing before (turbo to aussie, just opposite) New belhousing was only going to be about $400 or so. can't quite remember.
    Have a look at the CRS cat online and email for a quote. Or give em a call and they'll tell you exactly what needs to be done and the cost.
