I need to replace the Instrument Cluster in the SL 6cyl Auto VK.
Currently the cluster has the speedo/vacuum/fuel/battery/oil pressure/temp setup. Can I replace this with a RPM instead of Vacuum gauge and if so from what model?
Are BT1 clusters compatible with 6cyl?
The only real problem is the speedo is toast and cannot be repaired, perhaps I can change out the speedo and vacuum.
Can the 6 cyl Speedo be replaced with a V8 BT1?
Any other ideas appreciated![]()
just buy a VK 6 cylinder cluster with tacho.
Thanks, I have seen a BT1 Speedo and like the face better than the standard VK Speedo Face (a bit more stylish and accurate). Anyone know where I could get an overlay?
^^^ got two of them
pm'ed back
pm'ed again
pics pics pics
pics pics pics pics
anyone know where i can find another one of the vk bt1 dashes?
keep watching ebay. they pop up about once every two months ish
