Results 1 to 5 of 5
Thread: Varijet carb adaptor plate for XE carb
    Commodore
    Feb 2005
    Default Varijet carb adaptor plate for XE carb
    I would like to know where I can purchase an adaptor plate to fit the VK intake manifold so I can throw away the painfull Varijet carb and fit an XE Falcon 32-36 carb.
    I think the XE carb is the correct one to fit.
    When doing this mod is there anything else that needs to be carried out to enhance the fitting of the Falcon carb.
    Any help appreciated.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    This has been covered a number of times over the last few months have a look through older threads, but the final outcome was you should be able to remove the studs out of your current manifold and redrill it to suit the weber.
    Else KC do an adapter plate about $36 any parts supplier worth their own shoudl be able to get it for oyu.
    scott
    VB
    Jan 2005
    Central Coast NSW
    I am not really sure why you want to swap the varajet for the weber. The varajet is a good carb and works quite well with a modified 202, tune it correctly and it will run very smooth and give good power.
    what mods have you got?
    CAUTION:Any attempt to overtake will result in a race
    VH SLE 4.2
    Feb 2005
    I have an adaptor here that was bought to fit XE type weber to blue/black six cylinder manifold.
    It is a 'Lynx KC218', described as 'Adaptor kit Weber DCD 1-238 to GM 4 cyl'. Price marked on it is $38.50 but I paid less than that.
    Any speed shop should be able to get one in for you.
    regards
    Jeff
    EVL253's Avatar
    EVL253 is offline i hate cops!
    cranky black VB SLE
    Mar 2004
    yep this is a good conversion.ueses next to no fuel at all and goes real good.my mate had this on his 202VH.pulled it off and put a 350 holley on.holley went worse and chewed a damn sight more juice
  1. Which Carb??
    By vb_commie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2007, 05:43 PM
  2. 202 carb
    By VH_Commodore_Wagon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-11-2006, 07:20 PM
  3. Me and my Carb
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-08-2006, 09:16 PM
  4. xf carb
    By xstatic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-11-2004, 09:20 PM
  5. Vk Carb
    Last Post: 22-04-2004, 05:06 PM
