what do i need to place a VN 4 speed auto transmission into my 253 red V8? also would it work? cause the trimatic gearbox im using at the moment is pure rubbish.
or is there a way to get the most out of my trimatic? with only 3 gears fuel economy is not great, low down its sluggish and overtaking is very hard cause the kickback doesnt really go anywhere, just peaks out in 2nd.
You could get your trimatic beefed up, but doesnt fix your gear problem, you could look at electronic overdrive. I would use the converter, i cant remember what the problem was, but i remember their were a few people who had problems. Also you could get your block redrilled to turbo pattern, i no you can get it drilled one way but not the other, but im pretty sure you can get it drilled from tri to turbo.
Have a look here
About half way down this page theirs a diagram of the 2 different patterns. Sorry bout the link its the only place i can remember where the diagram is, thanks to a gen3 going into a landcruiser mmmmm![]()
