Hello, im gettin a vc 6 for free off my sisters bf, just wondering if vc-vh was the same style body for doors / windscreens / all parts etc, because i want to use this as a donor for my vh that im currently working on with a mate as our project car.
cheers
yes pretty much everything will be a straight swap same body up to VK.
sick thanks guys, also is it hard to put in the vk central locking? im pretty sure they had the central locking. cheers
Cant see why it wouldnt in terms of it actually fitting in the door, you may have to drill the neccasary holes but it all SHOULD fit in. Wiring maybe will be the hardest part, but shouldnt be to much trouble. If your doing the central locking from the VK, have you thought bout just grabbing VK calais doors, and having power mirrors, windows and central locking? Just something to consider.
My little bro (was 17 at the time) bought a cheap $40 central locking kit, fitted it to all four doors and wired it all up and had everything back 2gether all in one afternoon. Other then the normal tools in ya toolbox, I think all he used was an angle grinder to chop out a fraction of the inner panel to make the solenoids fit.
If u lived close by he'd prolly install it for ya reasonably cheap......I'm giving him $50 to install my central locking, alarm and immobilser. He's not dodgy either.....everything gets soldered and cable ties around everything to make it look as neat as possible.
I rekon I got some pics on here of the inner door panel which he took when he was fitting them to his old VK, if I can find them I'll post them up.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
