Results 1 to 10 of 10
Thread: vk+vp 3.8ltr+turbo=?
    1998 vs serries111 statesman 5.0
    Jul 2006
    Default vk+vp 3.8ltr+turbo=?
    gday guys posting this on behalf of my mate he has a vk and just brought a smashed vp 3.8 5 speed, and he wants to turbo it he got a turbo from autobarn its a kkr 380 rated at 380hp, we've seen on ebay the chips u can buy for the forced induction and also the 2 bar map sensors but wat were unsure of is injectors and manifolds
    1) what sorf of injectors dus he need were told standard are only good for 8psi of boost he wants around 11-12osi
    2) can u use the standard exhaust manifold with a j pipe set up or dus he need new custom ones?
    3) will an aftermarket fuel reg be needed if so wat type?
    4) he has a bosch 040 pump will this be good enuf?
    5) how strong are the bottom ends this motor is a recon so pritty fresh
    cheers for any advice muchly appreciated
    vs3 1998 5.0 statesman, pacy extractors, d&t twin exhaust,cai,kandn filter,,super lows, corvette survos & stage 2 shift kit/stallie, dvd, masive stereo 2nd ownner 146.000kms FOR SALE 0421388026
    3.8L GT35 4runner/VK calais
    Dec 2006
    Nowra
    1.S/C V6 injectors
    2.STD manifold will be fine
    3. recommended ,done go a cheap one
    4.may be depending on power out put
    5.as long as you dont run to much boost it should be fine
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Would be easier and cheaper and more reliable for him to purchase a VL motor.
    Dec 2006
    Nowra
    Quote Originally Posted by VL_5SPEED View Post
    yep or a skyline motor
    you can pick up a 2L 6 cylinder turbo 160kw motor for 2K with the box
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    Quote Originally Posted by GMMAD View Post
    yea that is a good point but i think its the fact that he already had a motor and just wants to make it work again, why buy another when you have one that has great potentual for cheap? also VP motors were incredibly powerful, more so than the RB30. also not prone to head cracking and has huge tourque.
    although the RB30 would be easer to fit.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Dec 2006
    Nowra
    Quote Originally Posted by Paiste402 View Post
    true ,but he wants to turbo it so it would be alot easier and cheaper to get a RB series motor and performance parts are allot easier to get
    but yeah the turbo V6 would be nice though
    Aug 2007
    Newcasstle
    Not to mention be more reliable (if both motors were turbo) and will respond better to upgrades and the rb30 also has a huge amount of after market performance upgrades readily available. The rb30 was basically designed for turbo and you can have the motor turbo charged using the stock turbo parts from around $500-1000. Or you could turbo the vp motor and spend around 2k on all parts including custom made parts. But its hes choice. If i was him I wouldn't waste my time and money turbo charging a buick v6 when he can use the nissan rb30. Easier cheaper and less hassles.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the RB30 conversion certainly would be easier as it's all off the shelf parts to make it work. there are plenty of turbo'd V6's getting around these days so it's not to dificult to do. custom pipes would be the best option in my opinion. many people are running em with 10-14psi without to many problems. the great thing is that should you blow the engine there are many more cheap ones avail. in the US they are running factory turbo's buick V6 engines making in excess of 1500hp (bloody shame holden never used em in the VN's) one ofthe mods they do in the US is to drill out the oil feed hole to on of the center main bearings because it's smaller then all the rest. i'm not sure however if the buick engines used by holden have this same quirk. the factory turbo engines also have much stronger crank/rods/ pistons combo to handle boost. obviously parts are avail if your after big numbers it's just that you will need to get em from the US
    Body by Holden, Soul by Brock
    the Legend will live forever
    Aug 2007
    Newcasstle
    Interesting... I wonder why Holden never used the buick v6 turbo? Holden haven't really had a good 6 cylinder since the VL turbo. Besides the factory super charged 6's what aren't even really known of.
    VP Executive R-spec
    Jan 2005
    The Buick turbo was finished by the time the new version of the V6 that the VN uses was in production. Also the VN was built for the RB30 everything on the car is setup for the RB even the stock cat back exhaust bolts straight up to the RB30's headers. The V6's Y pipe and everything to do with that motor in the VN was a fudge to make it work
  1. F/s Adelaide Vr Executive 3.8ltr V6 Sii
    By binkztarr in forum Parts And Other Items For Sale
    Last Post: 16-06-2006, 04:49 PM
  2. W T B - Holden 3.8ltr supercharged motor
    By fatterthanyamumma in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 11:55 AM
  3. 4'11 gears in vp 3.8ltr 5 speed
    By BADGM6 in forum General Discussion
    Last Post: 26-10-2005, 10:56 PM
  4. converting VS Ecotec 3.8ltr to VR 3.8ltr
    By ^Porter^ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2005, 02:18 AM
  5. VP 3.8Ltr Ute SWAP
    By hispeedvp in forum Swap / Wanted to Buy / Trade
    Last Post: 03-09-2005, 01:04 AM
