Results 1 to 2 of 2
Thread: Removing the steering column from a VK
    VK 6CYL 5SP
    Nov 2007
    NORTHSIDE BRISBANE
    Default Removing the steering column from a VK
    Hey all, when removing my steering wheel it was on too tight and i ended up collapsing my steering column ive got a replacement for it but i just cant work out how the linkage comes off the steering rack at the bottom? :S
    Any help appreciated
    What fun is having a licence and following ALL the rules?
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    To remove the VK steering cloumn, there's a knuckle connector holding it to the rack, take the bolt out so its completly free. Then remove column cover, and wires etc. Then there's two bolts up near the dash, then you can lower it down a bit. And up near the brake peddle their is one more, you will need a uni joint on your wrench to get to it, its a prick to get to, but once thats removed you should be able to slide it out.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  1. Removing dash off a VR Ute Column shift auto.
    By VTSSDUDE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 02:40 PM
  2. vr steering column
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2006, 06:47 PM
  3. Steering column bush
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-03-2006, 01:33 PM
  4. steering column key lock Help
    By sherr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2006, 08:11 PM
  5. WTB: VR/VS Adj Steering Column(Non AirBag)
    By Lexx in forum Swap / Wanted to Buy / Trade
    Last Post: 03-08-2005, 08:10 AM
