Results 1 to 4 of 4
Thread: VK Diff
    VK Executive
    Apr 2008
    Default VK Diff
    Is it possible to change the stock VK diff centre with an LSD centre in a 6 cylinder?
    also what is the difference between minispool and full spool?
    thanks
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Yes, i would have to be a 6cyl LSD centre to im pretty sure as they have different axles.
    I always thought a mini and full spool where the same, but im all ears.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Make sure u know wat diff it has. Some VK 6's had a Salisbury 8 bolt (which are ****), while others had a Borg Warner. Just make sure first. Finding an LSD for a borg warner isn't hard, they come up on ebay from time to time. I got out bidded on one which sold for about $150, so the next one which popped up I made sure I got, which turned out to be $250 with postage. Borg Warner diffs are used in a variety of cars, so that's one reason why it isn't hard finding an LSD for them. Just make sure it's 25 spline, coz that's wat the 6cyl VK borgy's were.
    And about a mini spool and full spool. A minispool only replaces the spider gears in the diff centre. You pull the gears out, and put the minispool in which locks the axle's together. A full spool is a complete centre which is locked. A full spool is a lot stronger, but for drifting and skids, a minispool would be all u need.
    VK Executive
    Apr 2008
    ohok, i see.
    thats one of the many modification to come to the vk. Sick of getting no traction when you need it.
    thanks
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Swap VZ diff for VE diff?
    By georgehifi in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-03-2008, 06:31 PM
  4. V6 diff in a V8
    By omar302 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-01-2008, 12:04 AM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
