Results 1 to 15 of 15
Thread: Problem With Vk Wagan
    Vs Esteem Series 2 Auto
    Jan 2008
    Cherry Gardens,Sa
    Default Problem With Vk Wagan
    i have a v6 vk wagan auto and when i start the car up theres a noise near the distributer cap somewhere,sounds like a loose belt or something but all the belts are good,we topped the trans oil up it was low,the noise goes away when ya put ya foot on the gas,anyone help ?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    What sort of V6 is it? (having a dizzy cap)
    and 3 Dangerous non ABS VN's
    Jan 2008
    Cherry Gardens,Sa
    88GreenVN's Avatar
    Jun 2006
    Hmmm I'm not much help on the old 6.
    Tom_1569's Avatar
    Tom_1569 is online now Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    EFI or carby?
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    Jan 2008
    Cherry Gardens,Sa
    its a carby,the noice goes away when u give it gas,the noise is drivers side near bottom of engine somwher
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Hmm, does the noise go away if you give in gas when its in neutral or park, or is it only when in gear?
    The only thing down that side of the car is the engine mount which could be worn, but i doubt it would make a worn belt noise.
    Can you describe the noise in greater detail or even film it.
    Jan 2008
    Cherry Gardens,Sa
    it does do it in park and neutral,the trans oil was on the add line i topped it up with some more and it does it still,also did a motor oil change to,i thought it was just the belts in the box because of the oil beeing low but the noise sounds like its near the bottom of the motor,hard to explain what it sounds like besides loose belts or kinda like a grinding noise,il make a small video of it tommorrow wth my phone.would it be the vaccum hose or something like that,when u start it up the rev meter sits on 5 & 6 grand but its only idiling.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Its probly not the Tacho, it will be the vacuum gauge and between 5 -6 is good for a cold start. Video would help
    Jan 2008
    Cherry Gardens,Sa
    ok thanks mate,would it be the vacuum hose making that noise. dont know much bout vk's i got a vs,il post a video tommorrow,how do i put it on here ?
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    just put it on youtube or something like that and link it here.
    A Vacuum hose shouldnt make a grinding noise, and the fact your vacuum gauge is reading accurate i would say its not a vacuum hose bit it wouldnt hurt to look around and see if you can spot any that are disconnected or broken.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by DANNY8 View Post
    maybe it's pinging, I think that's wat they call it....check ur timing.
    Ahh yes thats a very good point, one problem it will be EST, he cant change it, but i did find if i ran mine in standard unleaded it would ping and also run on, so i only use quality premium and it runs perfect.
    '85 HDT VK SS, '03 Liberty GT, '06 Forester XT
    Jun 2006
    if it was pinging it wouldn't go away when you put your foot into it, it would get ALOT worse!!
  15. #15
    DANNY8's Avatar
    Apr 2004
    Yeah worse, then it would come good. Like when u plant it in a too lower gear, as the revs get up it would stop pinging. Not always, but sometimes.....depending on the source of the problem. I also guess the auto advance would make it vary too. I don't know nothing about EST and the EST dizzy tho.
    My van did it heaps bad on ULP, as soon as the PULP kicked in it's rarely done it.
  1. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  2. vs wiper switch sedan to wagan
    By danny1987 in forum Electrical Wiring / Questions
    Last Post: 08-09-2006, 09:39 AM
  3. New Rear Wagan And Ute Lights
    By danny1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2006, 08:23 PM
  4. New Rear Wagan And Ute Lights
    By danny1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-08-2006, 06:38 PM
  5. Air Con Problem - Can anybody help?
    By lexcen-amue in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2005, 08:58 PM
