can anyone tell me wat is needed to put a turbo 700 from the vn vp into a vb ? i allready have a turbo pattern 308 !
any info would be awsome thanks
if memory serves me right the T700r4 is a lot wider then the early auto's and the trans tunnel will need modifying to fit the later trans
Body by Holden, Soul by Brock
the Legend will live forever
I had one in VC SLE had no issues installing it. I have pulled it out now and installed a T5 so I dont have any pics for you.
The VH had the T400 as an option which is bigger than the T700. So tunnel should be ok. It wasn't till the VL that they made the trans tunnel smaller. You will need a VN tail shaft front half and a modified gearbox cross member. The speedo will need to be changed to a wire type.
