Results 1 to 6 of 6
Thread: Restoring the brakes(after long time without use)
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Default Restoring the brakes(after long time without use)
    So here's the thing,my VB's brakes are crap use to not being used for a long time.When i look the top-up container thingy i see the fluid has gone pretty clear and there is dark **** on the bottom which im guessing is all through the brake lines,how do i clean it out and get the brakes working as normal again
    WTB:VR/S HSV 250km/h speedo cluster
    VS Calais & vh sl
    Dec 2006
    deception bay
    I would take the master cylinder out tip out the crappy fluid then clean it out with a clean rag and fresh fluid then put it back in and fill with clean fluid. then bleed the entire system, starting at the caliper closest the master cylinder using appropriate size clear tubing and a large clear jar bleed until the fluid coming through the tube is clear and your done. Make sure the master cylinder doesn't run out of fluid during this process.
    It would be a good idea to replace pads as well as they tend to deteirorate( i know icant spell lol) when the have been sitting in the weather for some time.I would also check your flexible lines for cracks and get someone to pump the peddle a bit while your looking at them to see if the buldge at all if so replace them and consider so braided one while your at it.
    If your not sure of anything id recommend getting a Gregory's manual and reading on how to bleed and stuff in there.
    shanhsv's Avatar
    May 2005
    Muswellbrook,NSW
    cheers mate,i may just replace the rubber bits anyway,just to be on the safe side.Im also gonna replace all pads and disc's.
    Also thanks for the advice,beta get me a repair manual so i know what im doing
    com-delivery is offline no sedan wagon or ute
    1983 vh wagon
    Feb 2008
    rainny coast qld
    VS Calais & vh sl
    Dec 2006
    deception bay
    how will he learn if he doesn't give it a go, just dont go to far on first run see if they work ok if you cant get it right it will cost ya a tow to a brake specialist for a bleed the rest is straight forward.
    shanhsv's Avatar
    May 2005
    Muswellbrook,NSW
    i have worked on brakes before but not like this,and not on an older car,should be fun.
  1. Hi everyone, long time no see.. you'll never believe it..
    By SeanV8 in forum VN - VP - VG - VQ
    Last Post: 11-12-2007, 10:09 AM
  2. restoring my vz sv6
    By redute112 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2007, 07:39 PM
  3. Restoring fading paint?
    By 1vngal in forum General
    Last Post: 06-11-2006, 01:11 AM
  4. VX leaking oil onto exhaust manifolds after not being started for a long time
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 09:54 PM
